remote start will not defrost windshield or warm interior
I will check back in august maybe some one has had this issue and have got the problem solved and if not I will not be needing to thaw the windshield or warm the interior and by then the way this truck is made I will need some one to not reply on helping me with air conditioning. thank you
I just walk out and start it like it does not have remote start I have been doing it that way for a long time any way and saves gas just one of the modern features that will be giving me problems I am sure there will be plenty more problems with this pos truck. thanks anyway
The gas mileage is terrible, the engine ticks loudly the transmission does not shift properly, the tires look like they are ready to be replaced with only 18000 miles on them, very small hail will dent this truck, amf fuel management does not activate properly, but the dealership says all this is normal I had to take it back for recall on the seat belts, The ticking noise was not there when I test drove this truck dealership tells me the noise is the fuel direct injection
oh...you came here to vent not for help.
if its any consolation, direct injection gas engines...the injectors do tick loudly. injecting fuel into a cylinder requires a powerful injector to handle the high fuel pressure. Have a listen to another truck with direct injection.
-factory oem tires for pretty much all makes; are done before the truck is off warranty....sooner if towing. if the tires have irregular wear...get an alignment.
-Can't comment on the trans concern but don't compare the truck to your old vehicle...compare it to another truck of the same year with the same build. The trans is built different so will have different shift qualities/ timing. for example; The new dodge 8 and 9 speed trans used dog clutches, built for efficiency...it takes more time for downshifts... but new owners think it should downshift faster like their old vehicle.
if the dealers keep telling you the problems are normal operation...have them show you on a similar build
Thank you tech 2 I am sorry for venting I just think expensive trucks should work as advertised and engineered to do after all I could have bought a used truck or just kept the old one I had for 20 years I guess my expectations are too high! thank you for all the information. I will try to stop complaining and just deal with the choice I made!
