Astro 1985-2005
Platform: M-Body
2000 Astro won't start
Old Aug 27, 2009 | 2:28 AM
  #11
helitiminaz's Avatar
Default Solution
Answer is..... the distributor was arcing from center post to #4 cylinder on each fire, thus the kickback. Although the crankshaft position sensor wiring was bad (probable not the sensor), I guess it wasn't the problem at all. Nor the new computer (ouch). Finally took it to a mechanic and he solved it in a few hours. Unfortunately for me, in this case I would have been better off to take it in in the first place. I think I'm still ahead (doing my own repairs) in the long run....
Tim
Old Aug 29, 2009 | 1:37 PM
  #12
Thumper_ehhhhh's Avatar
Originally Posted by 1Gary
Tim,
Make sure you use only AC Delco parts(cap,rotor,spark plugs,plug wires)because for these vans that is the only parts that last.
I second this statement 100%
Old Jan 2, 2012 | 6:21 PM
  #13
cd3766's Avatar
We have a 1999 S 10,it has a 4.3 L,it is in a no start condition,it cranks but thats all,the fuel pump is working,it has a new ignition coil,spark plugs and wires,we got a p366 fail code so we changed the crankshft position sensor.it still won't start,wiring to the sensor appeared to be good.any ideals next
Old Jan 2, 2012 | 10:45 PM
  #14
You may hear buzzing with the fuel pump but is there enough fuel pressure. Are you getting spark?
Imissmytoyota
Astro
Dec 9, 2012 10:37 AM
Sten
Mar 19, 2012 8:46 AM
2002chevyastro
Astro
12
Nov 3, 2011 3:04 PM
smd900
Astro
Apr 2, 2011 9:57 AM
catboater
Astro
Mar 3, 2008 6:33 PM
