2016 Camaro
Platform: F-Body & Zeta.
Car will not start
Old Oct 9, 2022 | 4:05 PM
jtrusty's Avatar
Default Car will not start
I have a 2015 Chevy Camaro LT that will not crank. The battery is good, the starter is good. I have done everything recommended that I have read......I have changed the key fob battery, ran battery cables from the battery to the starter (positive) and to the engine (negative) and nothing happens. I have also turned the key on to the on position for 15 minutes then to the ACC position tried to crank and nothing. Please help! Also the check engine light is on and it also says Service StabiliTrak. I hooked it up to scanner and it threw the code UO100. Please help I have no idea what else to do!
Old Oct 9, 2022 | 10:32 PM
Rednucleus's Avatar
Maybe you have a bad starter. Have someone hold the key in the "start" position while you gently tap the starter with a hammer. if it coes to life,time for a new one.
onerevolution
Feb 17, 2022 6:04 PM
Matt-K210
Apr 28, 2021 1:36 PM
Emily Rose Thompson
Aug 26, 2018 3:01 PM
brokenexpress
Feb 6, 2014 2:50 PM
usmcpeacock
May 17, 2012 2:29 AM
