Platform: B-Body
hardly moves
Old Sep 28, 2013 | 12:12 PM
  #11
WyrTwister's Avatar
Originally Posted by Sean Lapp
I would definitely check fuel pressure first make sure it is at the required pressure for that car, then if fuel pressure is low I would change fuel filter, check pressure again, if its low again I would then go to the voltage test at fuel pump connections at tank if power is at required voltage change fuel tank pump it should be easy this will be your second one you are becoming a pro! hope this helps
Changing the in tank fuel pump is defiantly a pleasure when the tank is 1/2 full of gas ! :-(
But it is a lot easier on the caprice ( tank located behind the rear axle ) than on the Lumina ( tank forward of the rear axle ) .
And it does not help when you are an old fat man & barely fit under the car , even jacked up ! :-(
Just be safe & support the care , secure and carefully on jack stands . And chock the front wheels .
God bless
Wyr
Old Nov 4, 2013 | 3:11 AM
  #12
LastTycoon's Avatar
I had a hesitation problem with an 89 I just bought, I changed the coolant temp sensor, fuel filter and then the MAP sensor.
I bought the MAP sensor at the salvage yard for $30 and it fixed my problem.
I had hesitation all the way through acceleration but it was much more noticeable in the higher gears.
Upon checking my PCV valve I could see signifiacant signs of sludge, I changed that and added some sludge remover to the oil whaile having an oil change done, I'm leaving on a 240 mile round trip tomorrow and I'll be checking the oil to see how dirty it has got whae I return, I expect it to get dirty quick if the sludge remover is doing it's job and will probably have to be changed earlier than usual.
Although a fuel pressure test could answer a few questions for you as well, unfortunately it is a process of elimination and I was lucky enough to get a result by going through a few of the cheaper and simpler possible fixes.
Good luck with your problem
Old Nov 19, 2013 | 3:53 PM
  #13
Blaidd Drwg's Avatar
LastTycoon, most sludge removers should only be in the engine a short time, they contain some harsh chemicals that will wash out your bearings quick if left in too long. Most of the stuff on my shelf states no more than 5-10 min in a running engine.
Blue92
Aug 16, 2013 11:38 AM
stillmuddin82
Mar 31, 2013 1:40 PM
veryscary
Jun 30, 2011 6:42 PM
haidangwa
May 3, 2011 2:19 PM
