Platform: J-body
Car bogs when I turn steering wheel.
Old Jan 15, 2007 | 1:31 AM
Slammedcav97's Avatar
Default Car bogs when I turn steering wheel.
When I am drivin stright or just sitting in neutral and turn the steering wheel it starts to bog out and feels as if it wants to stall. when I started is this morning it was at a normal idle for about a min and then i noticed the whole engine was rocking back and fourth, Anyone have anyidea what it could be?
Old Jan 15, 2007 | 11:12 AM
golfer's Avatar
Default RE: Car bogs when I turn steering wheel.
ORIGINAL: Slammedcav97
First thing first... when you cold started in the morning was the car running at idlerpm or was it at higher rpm then came down to idle rpm after a minute ?
Old Jan 15, 2007 | 3:33 PM
It was ata normal idle. then after about a min it started to bog out.
Old Jan 15, 2007 | 9:02 PM
golfer's Avatar
There's your problem... the car should start of at cold start idle of approx. 1200 rpm then come down to approx. 800 rpm.
Old Jan 15, 2007 | 9:43 PM
Well I have a Apexi Rpm and Speed meter thats electronic. and my RPMs are always around 920? rpms to about 1000rpms from what I see. But I don't get wht it would bog out to almost a complete stall when i turn a corner
Old Jan 16, 2007 | 12:30 AM
Syberia's Avatar
Does this problem only occur when the engine is cold? Does it only occur at idle or in neutral?
Old Jan 16, 2007 | 2:52 AM
It happens when I turn the wheel driving or in nutral, cold engine or normal running temp
Old Jan 16, 2007 | 2:56 PM
Syberia's Avatar
Does your steering, by chance, feel harder to turn when the car is not moving than usual? I'd hazard a guess that your power steering system is creating resistance somewhere along the way. Do you happen to be low on fluid? Additionally, I'm not sure how it is on this particular vehicle, but there's usually some sort of vacuum connection that raises the idle to compensate for the increased drag caused by the power steering pump. Is yours leaking/plugged?
cavman
Aug 21, 2009 10:15 PM
FlyinLow
Feb 19, 2009 12:25 AM
BP
Uplander
Oct 15, 2008 10:12 PM
jr19971500cpumobud
Nov 4, 2006 7:23 PM
