Platform: J-body
Cavalier engine problems
Old Dec 6, 2007 | 5:55 PM
mm1500lan's Avatar
Default Cavalier engine problems
My son purchase a used 98 Chevy Cavalier with HO 4 cylinder engine. It has 125000 mile and he is having nothing but problems. Great looking car he had it a month when it started to misfire, we replaced the plugs and coil packs spark plug wiring system. It ran great for a month, now we are having problems again. If the car is running under 1500 rpm’s it runs great. Push the accelerator any harder and it dies remove your foot from the accelerator and the engine will still run as long as you are under the 1500 rpm limit. It does the same thing in park. We are not finding any error codes. We have replaced the fuel pump after our GM mechanic told us to. $500.00 later the very same problem.
Old Dec 6, 2007 | 10:29 PM
John86's Avatar
Default RE: Cavalier engine problems
u could have a throttle position sensor problem. those don't always throw a code.
Old Jan 10, 2008 | 6:09 PM
franktorres's Avatar
it could be a number of things it can be throttle sensor, egr valve, or fuel regualtor
Old Jan 10, 2008 | 10:00 PM
ruffrider285's Avatar
all of those sensors always put out codes, wether the engine light stays on, or just comes on once and a while then shuts off.
Old Jan 13, 2008 | 2:45 AM
AsianGonCavy's Avatar
I have the same problem but its just hard speed up any one want to help me out (change spark plugs helped alittle) i was wondering if its head gasket 94 cavalier
Old Jan 13, 2008 | 11:21 AM
golfer's Avatar
Fuel pressure regulator?
Old Jan 20, 2008 | 4:52 AM
dirt_cavi_54j's Avatar
to me it sounds like a fuel pressure regulator or maybe even the fuel filter needs replaced
Old Jan 20, 2008 | 11:41 AM
shawnvw's Avatar
Banned
I would also have a look at the fuel filter. a clogged filter can starve the engine of fuel when it needs it the most. Although it should have been replaced when you did the pump
Old Dec 9, 2009 | 10:04 PM
ru_1980's Avatar
Check The small vacuum line that goes from the throttle body to the map sensor. I am not a well versed chevy man, but a buddy of mine had a 2.4 litre cavalier that ran extreemly rough and rich (black smoke) and I managed to locate the crack in that particular hose. New hose, ran like new. I don't believe the 2.2 litres have the same setup
Mom2ThreeACG
Traverse
Mar 12, 2018 6:20 PM
mwehrste
Dec 29, 2014 11:19 AM
p1thisfireburns
Aug 15, 2014 11:20 AM
cornett.danielle
Sep 12, 2010 4:11 AM
Eekmaddog
Mar 13, 2008 10:43 PM
