Platform: J-body
Loud grinding noise when trying to start. Solution?
Old Jul 2, 2016 | 1:56 PM
Landon Stubberfield's Avatar
Default Loud grinding noise when trying to start. Solution?
So heres the story, leaving work i went to start my car, it began to start but i let go of the key too soon so it started to die and i quickly (perhaps too quickly for everything to disengage and reset) turned the key again and the thing has been would make a very loud grinding sound like gears grinding. At the time i was kinda forced to just keep trying in spite of that noise and got it to start and i was hoping everything would be fine after that but i tried to start it last night and its just making the grinding sound and not turning over. I think i know what it is but Im hoping someone can confirm my suspicions.
Old Jul 2, 2016 | 2:29 PM
Rednucleus's Avatar
I wonder if you munched teeth on starter, or worse, on flywheel.
Old Jul 2, 2016 | 8:57 PM
sounds about right. start with the...err....starter. If its the flexplate/flywheel, you may want consider options as your probably looking at 1500$
Old Apr 1, 2021 | 8:35 PM
TruHD4nthaFloor's Avatar
Not a hard job to do actually if you have any experience mechanicing.
A transmission jack/motorcycle jack makes job super easy just unbolt housing to tranny underneath and leave all tranny bolts in their place and use jack to slide the tranny back a few inches so you can reach up there and unbolt flywheel. There's alot less mess than pulling motor out lot less to put bk in place!
Old Apr 1, 2021 | 9:36 PM
have you tried it on a stan dard trans?
Old Apr 5, 2021 | 4:03 AM
Well doesn't exactly make that easy when. You have the clutch involved...
Jessica Pulido
Mar 16, 2013 7:35 PM
anderhill
Astro
Jun 21, 2010 9:07 PM
oompaloompa7
Jan 8, 2010 2:34 PM
Venom90
Oct 4, 2007 12:13 PM
chowell
Jan 26, 2007 9:28 PM
