Platform: J-body
Reverse / Backing Wires Question
Old Mar 11, 2021 | 5:49 PM
MikkiD's Avatar
Default Reverse / Backing Wires Question
I’m trying to install a backing camera into a 91 Cavalier. The instructions indicate a Negative Ground wire that is Black and a Positive Reverse Light Wire that is Red.
I know this should be logical but am I to assume (correctly without screwing anything up) that the Positive Reverse Wire in this case is Green?
Old Mar 11, 2021 | 5:56 PM
kevinkpk's Avatar
Probably. If you have a volt ohm meter, check the connector pin to frame ground. That will tell you what it is.
Old Mar 11, 2021 | 7:41 PM
MikkiD's Avatar
I may have to stop by somewhere and have them check that. I’m pretty sure I have one but can’t recall where at the moment. 🤦🏼‍♀️
Hillhopper
1988 - 1998 (GMT400)
Oct 8, 2019 10:56 AM
beamerguy0
Jan 22, 2017 10:28 PM
Padre
Oct 24, 2009 7:31 AM
finerhomes
Jan 24, 2009 8:23 AM
scott_mckinney
Mar 13, 2007 1:07 PM
