Platform: J-body
Transmission problems?
Old Mar 24, 2011 | 9:29 AM
daven75's Avatar
Default Transmission problems?
When the car is cold, its fine, or in winter, its fine, but when it gets hotter out and the car warms up; when it shifts from 1st to 2nd it'll have like a shutter, you can feel it in the steering wheel along with basically the whole car. It wont really do it when im full throttle. When i "manually" shift from 1st-2nd it wont do it either.
The car has 110k miles. the tranny fluid was changed at about 98k miles.
Any ideas?
Thanks,
David
Old Mar 24, 2011 | 5:31 PM
EinST's Avatar
Welcome to the forum. It's hard to tell without knowing the year and trim level (is it even a Cavalier?) but, in general, the fluid level may be incorrect, leading to foaming, or a solenoid in the transaxle may be going/gone bad. Also, depending on the year, either the MAP sensor or TPS may be out of calibration. It's probably best to take it to a shop.
Old Mar 24, 2011 | 8:47 PM
daven75's Avatar
haha nice guess on the possibly not being a cav, its actually a 2001 saturn l200. umm as for incorrect fluid, i had a GOOD shop do it, so i trust them with that, i may take it to the dealer and ask them to check it. I possibly suspected the TCC solenoid, but wouldnt i be getting more than just this shudder if that was the case? I just replaced the TPS not too long ago cause that was my first thought, and i will be cleaning the MAP sensor in the next week, i dont have much time (college). but yea, any other ideas???
btw, thanks for the response, other forums i've gotten NOTHING.
Old Mar 24, 2011 | 10:19 PM
EinST's Avatar
I thought the SaturnFans forum site was still up. Anyway, the 1-2 shift usually involves a higher gear ratio transition and thus anything funny with the line pressure, or worn clutch pack for that matter, would be felt more. For 2001 I don't think the MAP sensor has any input in the shift logic. A visit to a dealership service department sounds like a good idea.
Old Mar 24, 2011 | 11:10 PM
daven75's Avatar
hmmmm ok, i also could check the lines and make sure their all still good, and yea it is up, and ive asked twice now, and have gotten nothing, you guys have given me more ideas! lol. sad i know. i figured it was a 4t40e tranny and a 2.2 ecotec, so basically its a cav.
Old May 27, 2011 | 2:13 AM
scoopster's Avatar
mine i unplugged TCC solenoid, and it worked fine, just to clarify if it is the problem
Old May 27, 2011 | 10:34 AM
daven75's Avatar
how did you go about unplugging the TCC solenoid? and will that cause any other problems??
Old May 28, 2011 | 4:53 AM
scoopster's Avatar
My cavalier 2.2 TCC solenoid is located on front drivers side at the top of tranny, its a big square plug with 3-4 wires, i am not sure where saturn is located exactly.
Old May 28, 2011 | 4:22 PM
daven75's Avatar
hmmm alright, Ill give that a shot! thanks man! have you found any problems by doing this though?
Old May 29, 2011 | 2:54 AM
scoopster's Avatar
i would put my car in gear and car would die, over and over or several times a day...after unplugging the solenoid it wouldn't die, which lets me know i need a new solenoid in transmission, cost was about $30
Coravir
Oct 26, 2019 3:28 PM
Mom2ThreeACG
Traverse
Mar 12, 2018 6:20 PM
mwehrste
Dec 29, 2014 11:19 AM
amos221
Mar 11, 2007 1:41 AM
