Ignition Question
Old Jan 1, 2008 | 6:07 PM
LCRick's Avatar
Default Ignition Question
Restoring 70 Chevelle. Currnetly in the process of starting engine, but when I turn ignition switch on starter engages immediately and does not stop until I turn ignition switch off. What could be the problem?
LCRick
Old Jan 1, 2008 | 10:31 PM
twizzle12's Avatar
Default RE: Ignition Question
With the wires off to the starter, see if you have voltage to the small wire with the key in the run position. if there is you have to figure out why. that little wire should only have voltage when you have the key in thestart position. the big wire should always have 12 volts to it obviously it goes directly to the battery.
Old Jan 2, 2008 | 10:02 AM
dewey's Avatar
After it starts, you might try turning the key back from the crank position, just a little, see if it makes any difference.
I agree with the other person, also check ignition feed to the starter solenoid, with the engine running.
You might check out chevelles.com, there is alot of tech info and forums.
nauticstar87
Oct 2, 2014 12:19 PM
boho115
Jul 10, 2013 7:15 PM
Truck Driver Bill
HHR
Aug 11, 2011 8:48 PM
BayouGhost
Oct 1, 2009 6:27 PM
mikeski
Feb 16, 2006 9:41 PM
