Engine Building & Overhauling All you ever wanted to know about building and rebuilding engines in here! Remember to post your model-specific questions in the correct section.
Manifold Exhaust Bolt Broken is it fixable
Old October 6th, 2012, 6:48 PM
hfdff's Avatar
Default Manifold Exhaust Bolt Broken is it fixable
Was wondering if I could get some advice on this. While doing a tune up this past week I found a broken exhaust manifold bolt and decided to fix it. The one I found I fixed with no problem by using an easy out.
While taking the exhaust manifold off I also found that I had another bolt that had broken. The bolt is the very aft bolt. Their wasn't much room to drill and I bought a angle drill that you put on your drill. I started drilling and thought I was centered but unfortunetly I wasn't and wound up drilling into the head a little bit.
I was wondering if I could drill out the bolt and put a Heli coil or will I be better off taking it to a shop and have them do it. Here are some pics.
Thanks for the replies,
Old October 6th, 2012, 7:13 PM
kevinkpk's Avatar
You might go ahead and drill/ezout the stud. If you cannot use that same size replacment stud, either overdrill it, and tap, or over drill/tap for a helicoil
Old October 6th, 2012, 10:11 PM
If you plan on keeping it, do it right. Doesn't look that bad at this point so drilling it out and making it the original size is the way to go.
Old October 7th, 2012, 4:21 PM
hfdff's Avatar
Thanks for the replies looks like I'll be pulling the head so I don't screw it up more than what it is.
Old October 7th, 2012, 4:26 PM
kevinkpk's Avatar
Why? Pull the exhuast manifold
Old October 7th, 2012, 4:31 PM
From the pictures I think he has pulled the manifold off and wants to pull the head also so as to gain better access to the busted bolt. I would agree its probably easier to address the busted bolt while working it from a bench, however you do open up a new can of worms pulling the head off....
Old October 7th, 2012, 4:37 PM
kevinkpk's Avatar
Yes anything able to work on a bench is better. If you can get even a camera phone in this vicinity, I'd think a drill would work?
Old October 13th, 2012, 3:54 PM
staggerlee's Avatar
Get a good sharp center punch to tap the center before drilling.
Then have a second person looking from the side to help ensure that you are drilling it straight.
Lee
Old October 13th, 2012, 5:43 PM
Site Ambassador
Camaro 69's Avatar
Can of worms is right. Were you even getting any kind of an exhaust leak? Pulling the head is the last thing I would do. If you can't get the bolt out, you might want to consider trying Percy's Seal-4-Good compressible gaskets. They're made to compensate for surface irregularities, and work great. I'd give that a shot before yanking the head.
Old October 15th, 2012, 8:59 PM
Jack Dorcic's Avatar
Try to weld a nut onto the broken bolt, very hard to weld cast zip it on and turn it out
dezem
April 19th, 2015 8:39 AM
Jimmy71
Express & G-Series Vans
November 11th, 2014 10:34 AM
frankcos5483
Avalanche
March 29th, 2014 8:34 AM
ddog96mn
Silverado & Fullsize Pick-ups
11
December 29th, 2013 8:35 AM
Michael J.
December 13th, 2013 10:13 PM
Quick Reply: Manifold Exhaust Bolt Broken is it fixable
