Equinox This SUV offers a smaller, sportier stance than the Trailblazer, all without compromising the SUV abilities.
Chevrolet Equinox
Platform: Theta
2007 Equinox Heater problem
Old February 16th, 2020, 9:38 PM
phil_hert's Avatar
Default 2007 Equinox Heater problem
Have a 2007 Chevy Equinox
Heater / Air were working fine.
Smelled antifreeze when turning on heat – and saw small amt of fluids on garage floor.
Took to shop – they found water pump leaking – replaced.
Heater now not working properly. Feel heat while sitting and going slow – but when travelling to highway speed – blows cool air.
Still smelled antifreeze – further checking – replaced bad heater core.
Still no heat.
Shop cleaned out hoses, etc and now replaced radiator.
Still no heat at higher speeds.
Shop seems stumped. Thoughts?
Old February 16th, 2020, 10:52 PM
are you getting a p0128 code?
Old February 16th, 2020, 10:57 PM
I'm here for the party
Irish_alley's Avatar
could the blender motor/door be stuck? not sure about the equinox but i know the early 2000's trucks had this issue of the heater core was leaking. it would drip a small amount around the blender door and then dry up and cause it to be stuck in one position or another. also if the coolant was just about topped off it would also blow cooler air.
Old February 18th, 2020, 8:32 PM
phil_hert's Avatar
no codes show
Old February 18th, 2020, 8:34 PM
phil_hert's Avatar
how would I know if the blender motor/door was stuck?
Old February 18th, 2020, 8:37 PM
can you hear it move?
Old February 18th, 2020, 8:40 PM
phil_hert's Avatar
sorry, ignorant here, will it move when the temp control is moved from cold to hot and back etc
Old February 18th, 2020, 10:48 PM
it should move. you should hear it around the passengers side floor board. might "clunk" might just slowly wind into position.
Old February 19th, 2020, 12:23 AM
ruley73's Avatar
Make sure the cooling system has been sufficiently bled. The 3.4L in the Equinox is a challenge to bleed. I highly recommend parking the vehicle on an incline to make the bleeder screw the highest point in the cooling system. A shop should know better, but this is easy enough to try yourself. All you need is a 7mm socket for the bleeder screw - which is located above the water pump housing.
Chevy_Nox
Equinox
January 19th, 2022 9:31 PM
shawnaschafer
Equinox
January 24th, 2020 10:04 PM
Justin Nelson
Equinox
October 20th, 2019 6:45 PM
Mommyrocket84
November 11th, 2014 1:49 PM
odigidy
Silverado & Fullsize Pick-ups
February 7th, 2007 12:06 AM
Quick Reply: 2007 Equinox Heater problem
