Van Misses Badly, But Only At Idle--NO CODES
Old July 1st, 2013, 9:31 AM
TinyDriver's Avatar
Default Van Misses Badly, But Only At Idle--NO CODES
I have a 2004 Express with the 6.0L gas motor. It has developed a problem where it will miss to the point of almost stalling, until gas is applied. Once you hit the accelerator, it smooths right out. I'm starting to wonder if the throttle body is dirty or something similar?
Please respond quickly, as this vehicle is the only means of transportation for our family of 7.
Old July 16th, 2013, 6:13 PM
TinyDriver's Avatar
bump.
I will be disassembling and cleaning the throttle body this week. Anything else I should do?
Old July 16th, 2013, 7:22 PM
BillJ's Avatar
Take a look here ... they seem to have good tips ...
Troubleshooting Problems With Engine Idle
Old July 20th, 2013, 4:46 PM
canucklehead's Avatar
upstream o2 sensor? Clogged muffler....(rusted out)? Spark plugs?
Old July 20th, 2013, 5:06 PM
TinyDriver's Avatar
I'll check on the O2 sensor. I'm pretty sure the muffler is fine, as the exhaust system is in stellar condition. Spark plugs are only a year old, but still worth checking.
Old July 21st, 2013, 9:57 AM
TinyDriver's Avatar
Could it be the fuel filter?
Old July 21st, 2013, 1:04 PM
Yes. But also, you could have a bad spark plug. My dad built a car and it had brand new everything, and he had a vibration....turned out to be a bad non firing plug.
Could also be sticking valves.....
Change the fuel filter, and check those plugs for spark....then maybe throw some fuel system treatment in the next few tanks
Old August 22nd, 2013, 9:35 AM
TinyDriver's Avatar
Default Fixed!!!
Well, we finally got it running smoothly. We replaced all the spark plugs. Turns out, one of the boots hadn't been fully replaced, and so it was arcing. Two other boots came apart, so we replaced all the boots too. Never worked with Coil-Near-Plug systems before. It's kinda nice not being able to cross plug wires.
Thanks for the help everyone.
daveyjones21
Silverado & Fullsize Pick-ups
November 26th, 2010 6:46 PM
cris2for
May 6th, 2010 11:18 PM
shadowbunny
June 18th, 2007 3:46 PM
grimani7
April 16th, 2007 10:14 AM
Quick Reply: Van Misses Badly, But Only At Idle--NO CODES
