1990 G2500 w/5.7 Dies without warning
Old Feb 21, 2022 | 7:54 PM
wa9zug's Avatar
Default 1990 G2500 w/5.7 Dies without warning
We have a 1990 G2500 van with a 5.7. It dies suddenly. Happens randomly at various speeds. More so when lower RPM's. If I crank it a while it will start back up. I pulled a plug wire while it was turning over to restart it I saw spark( verified three times). I had no gas spraying in the TBFI. If I spray a little carb cleaner in the TBFI it will fire up and stay running. I drove around with the doghouse and air cleaner off and when it would die I saw No gas spraying, but as soon as I sprayed a little cleaner it would fire up (did this many times). What am I missing? It seems like both TBFI's are turning off at the same time and then they turn back on when I spray the cleaner. I don't get it. Haaaalp!
Old Feb 21, 2022 | 8:55 PM
GBousley's Avatar
If fuel delivery fails could your fuel pump be going out? I think you can put a gauge on the return line to monitor pressure (someone keep me honest here). Also, if you haven used a TBI rebuild kit in a while they work wonders (if it's not pump related). I removed both injectors in my 305 TBI and cleaned them and noticed a huge difference in how they sprayed afterwards (along with the rebuild kit).
Old Feb 21, 2022 | 9:01 PM
wa9zug's Avatar
Thanks for the reply. It stops spraying like a switch is turned off. It starts spraying as soon as I spray some carb cleaner (or starting fluid) in the TB, It will run and then die quickly without a stutter. BTW never heard of a TBI rebuild kit.
Old Feb 21, 2022 | 9:35 PM
wa9zug's Avatar
Do these TBI's have fuel pressure regulated to them? How? Is it vacuum?
Old Feb 21, 2022 | 9:43 PM
GBousley's Avatar
See: https://www.autozone.com/fuel-delive...-tbi/gmc/g2500
Replaces all gaskets, and fuel regulator. As for TBI, I know it needs a specific pressure / volume from the pump, and I'm sure there's a return line to the tank. Not sure on the specific numbers.
Old Feb 22, 2022 | 7:38 AM
William Kisselstein's Avatar
Throttle Body Injection runs about 13-15 PSI from a pump in the tank, which you should be able to hear running.
Did we replace the filter? Is the tank dirty?
These are OBD-1 systems and can be checked for trouble codes by connecting a wire (bent paper clip works) between A and B terminals on diagnostic link, turn ignition on and count flashes of check engine light. It shows two digit codes by flashing each one three times. 12 is normal. They will not give as much information as an OBD-II system does but it can be a help.
Old Feb 22, 2022 | 9:34 AM
wa9zug's Avatar
Does that rebuild kit give you the stuff to rebuild the pressure regulator, or is that a separate item?
Old Feb 22, 2022 | 10:10 AM
GBousley's Avatar
Yes, it's the small orange piece (gasket) with a spring. Just make sure you enter your vehicle details and ensure the kit matches your application.
Old Mar 6, 2022 | 7:54 PM
wa9zug's Avatar
Popped in a TBFI rebuild kit and VIOLA, no more issues! Talk about nailin' it! Thank you O wise sages.
Old Mar 7, 2022 | 9:00 AM
GBousley's Avatar
Awesome! Glad that worked out!
Dfmatt
1988 - 1998 (GMT400)
19
Aug 29, 2024 1:02 AM
Oliverc2004
Mar 21, 2022 6:32 PM
StankyWankyKime
Jul 13, 2018 8:54 PM
1985_S-10_Durango
Jan 28, 2018 1:38 PM
Andrew1320
Sep 24, 2014 3:11 PM
