2015 express no crank no comm
Old Jan 11, 2024 | 4:42 PM
2015Chevyexpress15's Avatar
Default 2015 express no crank no comm
No Crank, No comm. PRNDL does not illuminate and I cannot communicate with any module. I found a blow bcm fuse, and broken engine to chassis ground strap. replaced the fuse and replaced the ground strap, No changes
Any ideas?
Old Jan 11, 2024 | 5:08 PM
if the engine strap was broken, then the battery wasn't charging.
Try boosting it from another vehicle, and then getting your battery + alternator load tested.
Old Jan 11, 2024 | 6:15 PM
Tried boosting, charging, the Van will not start.
no communication with any module, and the prndl does not display on the dash.
Old Jan 11, 2024 | 6:31 PM
did you go through and check ALL the fuses? under the hood and in the cabin?
if the ground strap was broken, all that starter current might have back-fed into various other systems and fried things out. Use a meter to see if you have a reliable low-resistance ground on all the modules. You'll need schematics and pinouts which you can get from sites like gmupfitter.com and charm.li
Old Jan 21, 2024 | 3:57 PM
JimMessner's Avatar
I have a similar issue on my 2010 Van too. Starter wont turn over or even click.
We were going to leave on holidays with it tomorrow!
I replaced battery and no change.
The PRNDL does not light up and the signal lights do not work?
Everything was working well when parked about 3 weeks ago. (Battery always dies after being parked that long).
It's a Roadtrek Camper Van but I don't think that has anything to do with this issue?
I'm going to check the fuses under the hood tomorrow morning before I call a Tow Truck.
Its parked in a storage yard and I can't do much else unless someone has some good advice.
Thanks in advance!
Old Jan 21, 2024 | 6:20 PM
it could also be a bad ignition switch
Old Jan 21, 2024 | 8:45 PM
Triaged's Avatar
Originally Posted by JimMessner
Everything was working well when parked about 3 weeks ago. (Battery always dies after being parked that long)...
Shouldn't kill the battery after 3 weeks. Might want to start with that parasitic draw first. Any rats living under the hood?
Old Jan 22, 2024 | 9:26 AM
JimMessner's Avatar
Its been -25 to -40 degress the last few weeks here. Just starting to warm up to above freezing. We dont have any rats or mice this time of year but perhaps a rabbit?
tljones7870
Sep 13, 2023 11:03 AM
funtwodrv
Apr 4, 2023 8:39 AM
birdman3131
Jun 21, 2019 11:32 AM
copleycop
Mar 4, 2015 4:01 AM
Tgoodrich3
Apr 25, 2012 8:36 PM
