crate engine wont start
Old Jan 18, 2015 | 12:43 AM
chignola's Avatar
Default crate engine wont start
installed chevy performance long block crate engine.with brand new edelbrock performer 1406 carb,msd hei street fire distributer .she wont start and the plugs are dry.how and how much fuel does it take to get her started.all cyl have spark.and fuel squrts out of the accellerater pump.
Old Jan 18, 2015 | 1:58 AM
canucklehead's Avatar
Is the timing set right?
you could put a little gas down the throat....
Old Jan 18, 2015 | 2:45 AM
chignola's Avatar
timing right,how much gas and how
Old Jan 18, 2015 | 2:48 AM
lonewolves's Avatar
ignition timing is correct?
Old Jan 18, 2015 | 2:53 AM
lonewolves's Avatar
Originally Posted by chignola
timing right
ok ...
dismantling the air filter and
put some gas into the venturi port of carb.
one swallow, approximately 30-50 ml
Old Jan 18, 2015 | 3:26 AM
chignola's Avatar
with dist power removed? turn motor over for about 10 sec?let rest for how long before restarting ?how and when do you know gas has gotten down to all the cyl's ? so you can plug dist power back in ?
Old Jan 18, 2015 | 7:47 AM
solwav's Avatar
If you have fuel and spark if should at least attempt to run. If the plugs are dry, a good guess is a fuel issue that is where I would start. Spray starter fluid into the intake if the engine does not even try to fire move onto the ignition system.
Old Jan 21, 2015 | 9:40 AM
Did you get it running?
Old Jan 22, 2015 | 8:13 AM
solwav's Avatar
Good question, how is you fuel delivery?
Old Jan 23, 2015 | 10:39 AM
DougE's Avatar
Ditto Solwav. Pull the air cleaner and give it a shot of starting fluid. If it doesn't fire you most likely have a fuel delivery problem. Make sure your ignition timing is right and that you're not 180* out on the distributor install.
chignola
Jan 18, 2015 1:02 AM
Kerazyguy
Jul 10, 2014 11:41 PM
jeepmkcomin
Apr 9, 2009 11:53 PM
superk10
Jan 21, 2008 7:43 AM
HouseOfWheels
Dec 15, 2007 5:55 PM
