Short in stop light - where to start?
Old Nov 16, 2013 | 11:40 PM
wgander's Avatar
Default Short in stop light - where to start?
All of the light bulbs work correctly individually. When the running lights are on and the brake pedal is depressed, the lower bulb on the right had side does not illuminate. It does illuminate when the running lights are on, and also when the brake pedal is depressed but, it goes out when both running and brake are activated.
Where do I start looking for a short?
1997 Chevrolet 1500 Express Van with 5.7 Vortec engine and trailering package.
Old Nov 16, 2013 | 11:50 PM
canucklehead's Avatar
Inside the bulb itself. If one filament touches the other, it can cause wierd stuff.
Old Nov 17, 2013 | 9:01 AM
Also look at the socket to make sure the bulb seats correctly and that it has no loose contacts and is not corroded.
Old Nov 18, 2013 | 5:50 PM
wgander's Avatar
Default follow up
I swapped the left and right side light bulbs and nothing changed. The right side still doesn't work when both the running lights are on and the brake pedal is depressed. I didn't see any corrosion on the bulbs or sockets, and all the wires look OK.
Next idea?
Old Nov 19, 2013 | 11:20 AM
When the right side bulb will not come on, move the bulb back and forth in the socket and see if this changes anything. If it does then there the bulb is not seating correctly in the socket.
Old Nov 19, 2013 | 11:22 AM
wgander's Avatar
It doesn't seem to be a bulb or socket problem. They are both clean and the bulb is a snug fit with no movement.
Old Nov 20, 2013 | 12:33 AM
My guess would be a bad grounding issue somewhere in the line. Check the wires from the bulb down. Also check to see if there is a relay involved.
Old Nov 20, 2013 | 1:13 AM
wgander's Avatar
I think I have to connect my trailer lights and see if I have the same problem. I know the trailer lights work, but I didn't check them with both running lights and brakes on. If they work OK, the problem must be in the wires to the back of the van only. If the trailer lights also don't work on the right side when lights are on and brakes applied, I guess I'll have to crawl under the van, find out where the trailer wiring harness begins (it was standard on this vehicle), and check the wiring starting right before the trailer harness.
wgander
Apr 28, 2013 7:49 PM
fraser jim
Feb 15, 2012 11:23 PM
Juli O Sanchez
Oct 10, 2007 7:42 PM
mgshilling
Sep 17, 2006 1:28 AM
mfishgutz
Jun 25, 2006 12:20 PM
