General TechGood at troubleshooting? Have a non-specific issue? Discuss general tech topics here. IF YOUR QUESTION IS SPECIFIC TO A CERTAIN MODEL, IT DOES NOT GO IN THIS SECTION.
TAP on the carb with the handle of a screwdriver or soft hammer. I suspect the float is stuck, other than taking the top off, that's the short solution.
choke stuck , float struck open-dropped filling the carb with fuel, not sure if that vehicle has a purge valve if diaphragm is torn it will pull fuel from the carb.
Hey can anyone tell me what is that thing seating on the middle left. I can name crank pulley, generator and water pump and that thing is probably air injection pump? Is there filter in it?
