1999 K1500 GMC Suburban Fuel Issue
Old May 11, 2020 | 8:14 AM
Kperinuzzi's Avatar
Exclamation 1999 K1500 GMC Suburban Fuel Issue
Hello all,
My father does not have money to get his Suburban fixed so I will be taking on the job. When you start the truck it turns over but wont start, try it a second time and it starts right up. My dad he has had this issue before and new fuel pump has corrected the issue. I ordered a new fuel filter and fuel pump from Rock Auto., the pump has 4 prongs, I am worried the one in my truck is a 2 prong pump. Also do you believe changing the fuel pump will fix the issue? Turning the key partial I hear the pump (priming), If i do this twice then the car starts right up. Anyone know what the issue is? and how difficult is it dropping the tank and replacing the fuel pump?
Old May 11, 2020 | 9:44 AM
Welcome from Florida. Sounds like the check valve in the fuel pump assembly is bad. It is letting the gas bleed back into the tank when not running. I had that problem a few years ago in a Silverado and I added a check valve into the fuel line near the gas tank. This solved the problem.
Old May 11, 2020 | 10:11 AM
Kperinuzzi's Avatar
That is what research has been telling me, it is the check valve in the fuel pump. Because I hear the fuel pump working when I turn the key. With the check valve being bad is it putting strain on the fuel pump?
Old May 11, 2020 | 10:18 AM
Rednucleus's Avatar
As Oldchevy said, the simple & inexpensive fix is to add an in line check valve; send the new pump back to RA
Old May 11, 2020 | 10:28 AM
Kperinuzzi's Avatar
That would be great, where exactly would you guys install it? and may you please send a link to the exact piece I would need for my 1999 GMC K1500 Suburban, please?
Old May 11, 2020 | 11:01 AM
Kperinuzzi's Avatar
8mm? What size hose should I order?
https://www.amazon.com/Return-Check-Petrol-Diesel-Aluminium/dp/B06XK215S7/ref=sr_1_4?crid=2E89J1JMI1J0I&dchild=1&keywords=fuel+line+check+valve&qid=1589212715&sprefix=fuel+line+check+%2Caps%2C138&sr=8-4 https://www.amazon.com/Return-Check-Petrol-Diesel-Aluminium/dp/B06XK215S7/ref=sr_1_4?crid=2E89J1JMI1J0I&dchild=1&keywords=fuel+line+check+valve&qid=1589212715&sprefix=fuel+line+check+%2Caps%2C138&sr=8-4
Old May 11, 2020 | 1:34 PM
Make sure the gas hose you use to make the connections is rated for fuel injection and not just regular gas hose. I installed mine as close to the gas tank as I could get it.
Old May 11, 2020 | 1:47 PM
Kperinuzzi's Avatar
Im worried the sleeve under the fuel pump may be gunked up, I am going to drop the tank and replace the pump for peace of mind.
Old May 11, 2020 | 2:31 PM
If it is gunked up, you should have the tank cleaned as there is probably more gunk in there.
Old May 12, 2020 | 6:29 AM
Kperinuzzi's Avatar
I will clean it out, thank you guys!
XAQSHNR
K5 Blazer
Mar 29, 2020 5:16 PM
mom3allen
Feb 19, 2017 2:05 PM
f7cat
Nov 27, 2012 10:16 AM
plunkj
Apr 26, 2011 5:12 PM
Khazlett
Jan 19, 2010 1:29 PM
