2014 Cheverolet Suburban A/C Issues
Old Apr 11, 2022 | 11:58 AM
Bigred205's Avatar
Default 2014 Cheverolet Suburban A/C Issues
I have been having issues with my suburban's A/C. In the Summer time with A/C is on. If the battery gauge on the panel shows at 14 the A/C runs fine but if the battery drops around 13 it quits blowing cold air. If shut off the suburban and turn it back on it goes back to showing battery at 14 it will blow cold air. I've taken it to different people they've checked the A/C and said its working fine. Ive replaced the battery and didn't fix the issue. I was hoping some could help me out.
Old Apr 11, 2022 | 2:30 PM
Recklessabandon's Avatar
More then likely you have a charging system problem. If your alternator is weak and the voltage is dropping, the truck will start shutting things off to conserve energy. A new alternator will be probably fix the problem.
tjm3
Jun 25, 2019 2:01 PM
Ronald Greenwell Lollis
May 14, 2019 9:22 PM
silfies02
Traverse
Jul 15, 2018 9:22 AM
Texas556
Jun 13, 2017 7:46 PM
CarolinaJ
May 23, 2012 4:57 PM
