454 big block How much cyl. comp.
Old Sep 27, 2011 | 10:18 PM
baycitygreasemonkey's Avatar
Default 454 big block How much cyl. comp.
Hey guy's,
How much cylinder compression should a 454 have.
I am getting 130-140psi is that ok?
Old Sep 28, 2011 | 8:13 AM
T.Neff's Avatar
Banned
More importantly is the difference one cylinder to another one.Of course I mean within reason.What is the highest one to the lowest one??.Why do you ask??.What is the issue your dealing with??Judging the condition of a engine is more the job of a leakdown test.
Old Sep 29, 2011 | 7:26 AM
I was just wondering. I have 130-140 @ all cyl.
10psi different. This is not to bad
I have been chasing a problem this thing is running Rich. It is a TBI 454 1992>
No codes had a bad injector so I replaced both. I have 12psi fuel pressure which is within spec. #1 is oil fouled with a 140 comp @ that cyl. Possibly
Vavle guide or seal, mybe an oil ring stuck.Could this cause this thing to run rich?
I had codes for ecm temp switch & 02 sensor that I had replaced.
The map sensor is good. I don't seem to have any vacume leaks.This engine is driving me mad.
Any advice would be appriciated.
Thanks
Old Sep 29, 2011 | 10:19 AM
T.Neff's Avatar
Banned
Have you checked the throttle position sensor??.What makes you think it is running rich??.The oil foul,percentages are in favor of guides/seals.As a matter of policy we always do both heads because the rest are sure to follow as a issue soon after you do one side.How many miles are on this??.
Old Sep 29, 2011 | 3:10 PM
kevinkpk's Avatar
Thanks
Is the O2 sensor you replaced on the exhaust of #1 cylinder? I don't know what effect that would have on fuel schedule if it were. I'd suspect valve seal also as tthe compression is good, and 130-140 (don't have the specs) sounds good. If it were an oil control ring, I'd say high crankcase pressure (blowby), and lower compression. My $.02 worth.
Old Sep 30, 2011 | 7:27 AM
2 months ago it threw a code for the tps I replaecd it.
Driver of this p-van is complaining of the rich fuel condiion. I believe it was a number of these issues, I put a hotter plug in it with a nonfouler & it also helped a little more.
I don't know how many miles or hours.It is ran at the port in a yard @ mostly under 25 mph.
Thanks guys I will probubly inspect & replace the valve seal @ #1 intake.
Old Oct 1, 2011 | 12:55 PM
T.Neff's Avatar
Banned
Aaaaaaaaaaa-like I said,if one seal went bad,the rest are sure to follow.LOL-band-aid repair??.Yeah had to poke ya some on that one.I sorry.LOL.
Old Oct 1, 2011 | 1:06 PM
kevinkpk's Avatar
Yea, you should replace ALL of them.
chrisk
Jul 6, 2016 7:14 PM
philgethifi
16
May 27, 2009 11:52 PM
Gwampa
Apr 1, 2009 9:27 PM
