Abs and ignition help
Old Oct 21, 2012 | 6:40 PM
s10 lover's Avatar
Default Abs and ignition help
I'm having two issues with my 06 Equinox lt awd. ill explain them both seperatly. And i have NO warning lights on, they all come on when starting the vehicle but turn off shortly after.
1. the abs is kicking in while on dry pavement, and lightly braking. Dosent kick in during hard braking. the abs sensors are clean and debris free, brake pads and fluids are good.
2. Somtimes when staring the vehicle the engine doesent start right away it acts like its almost hesitating. only happens sometimes not always. the ignition coils seem good no corosion no loose connections.
Any help on these issues is greatly appreciated. Thank you in advance.
Old Oct 23, 2012 | 12:21 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> s10 lover,
This may be related to the BCM. This is just a suggestion, not a diagnosis. I would recommend having the vehicle inspected for additional information.
Please keep us posted.
Louis
GM Customer Service
stanman
Aug 12, 2013 2:49 PM
boho115
Jul 10, 2013 7:15 PM
Truck Driver Bill
HHR
Aug 11, 2011 8:48 PM
