Another name for a “Driveshaft Front Yoke Seal”?
Old May 21, 2021 | 6:48 PM
Eric Kothe's Avatar
Default Another name for a “Driveshaft Front Yoke Seal”?
A shop told me I need a “driveshaft front yoke (oem) seal. I looked for it on rock auto but couldn’t find it, what might another name be?
The problem is it’s leaking around the output seal but that was replaced twice.
Also, how easy is it to do if I find the right part?
Old May 22, 2021 | 1:07 AM
the seal is located in the tcase if 4wd so its called a tcase rear output seal....if you have a 2wd its a trans rear output seal
Old May 22, 2021 | 1:45 PM
Eric Kothe's Avatar
Hey
it’s a 2wd. I believe that it’s had two rear output seals done and they moved onto what they called the yoke seal. But it does seem to be coming to it if the output seal
Old May 22, 2021 | 8:22 PM
crawl under, find the leak point and post a pic
Old May 23, 2021 | 4:51 PM
Eric Kothe's Avatar
Old May 23, 2021 | 5:26 PM
if its leaking thru the center of the slip yolk out to the ujoint...it needs a slip yolk/driveshaft....never heard of a slip yolk seal.
Old May 23, 2021 | 8:05 PM
Eric Kothe's Avatar
thanks
i can’t find a seal for it and it shifts perfect. Is it likely you’d use rtv to seal it?
Old May 24, 2021 | 11:32 AM
ru referring to applying rtv to the back side of the slip yoke? would be hard to access without removing the ujoint from the yolk.
Old May 24, 2021 | 1:11 PM
Eric Kothe's Avatar
yeah it seems like there’s a metal cap on the end that can be the source of the leak. And the two options can be replace the whole yoke or seal the cap with rtv
woodie1987
Nova & Chevy II
Nov 22, 2014 9:22 AM
ccd
Jul 20, 2013 9:31 PM
BIGREDDNESS
Feb 20, 2012 10:07 PM
smokenjoep01
Nov 6, 2010 8:06 AM
porsche 84
Jul 5, 2007 9:32 PM
