Need help!!! Need a Heim Joint for 2008 Chevy Suburban
Old Dec 27, 2024 | 7:24 PM
  #11
starman8tdc's Avatar
Spacer welded to the drop bracket between the bracket and the piston, or a stack of threaded nuts welded together to act as a spacer? Then use a 2" thick drop bracket with gusset style reinforcement to prevent bending?
Old Dec 27, 2024 | 9:55 PM
  #12
How bout repositioning the drop bracket to the outer tie rod?
Would that work?
Old Dec 28, 2024 | 10:47 AM
  #13
Or this?
Old Dec 28, 2024 | 1:23 PM
  #14
I had given up on the bracket idea, but just to be certain - I just went out and removed the inner tie rod boots, and then turned the wheel hard over in both directions. I might have an aftermarket rack or something, but on my rig - the rack pistons do not go into the rack tube. So I should be able to use the bracket idea without limiting the steering. Thoughts?
Old Dec 28, 2024 | 4:46 PM
  #15
Latest design idea:
Old Dec 31, 2024 | 11:07 PM
  #16
Gumby22's Avatar
Where there’s a will, there’s a way.
I’m not sure on the mods - I just know how these systems are supposed to work (meaning with a factory setup) and have very limited experience with lifts in general, let alone those requiring the level of modification that you’re seeking.
At a fundamental level, the mods you’re thinking of will work in theory ​​​​- however I think you’ll find that what seems like a simple solution is often more difficult to achieve than one would expect. Steering & suspension is designed to work while under the force of thousands of pounds per square inch that’s been focused into a few key points throughout the system. Symmetry & accurate Geometry is key to keeping it functional & safe.
This is a situation where you’ll have to start trying your ideas and see how they work.
The only advice I have left to give is be careful and make safe decisions.
Good luck.
Old Jan 1, 2025 | 1:11 AM
  #17
I hear ya, and I agree 100%. Thanks for the input.
2KBurb
Dec 31, 2024 8:14 PM
crystallee3
Oct 18, 2013 10:05 AM
Avenger
May 31, 2011 8:21 AM
jake357logan
Jan 6, 2010 9:47 PM
smitty6
Aug 7, 2006 8:31 PM
