Rebuilding/Cleaning up 350?
Old May 19, 2009 | 5:15 PM
  #11
jjhearn's Avatar
Ok guys, 1 quick question. I was out there yesterday just foolling around wiping the accesible parts down. I pulled the air filter, of course it is as black as the tires, but when I went to put the bottom cover on, I noticed it sat on top of my plug wires that connect to the distributor cap. About a good inch or more. Is that normal? Should that be way? I will get another pic up, and also the dimensions on the filter to determine filter number to replace. Just figured I would drop this out while I was thinking about it.
thanks
JJ
Old May 19, 2009 | 8:45 PM
  #12
jjhearn's Avatar
Ok. this is what I was refering to in the above post.
Also, the dimensions on the filter are 13 3/4" outside diameter and roughly 3 7/8" tall. Should it be that big?
Also, when I called about the filter, my sales guy told me he would need to know the make of what it came out of being that all the models that shared the engine had diffrerent air filters. Is there a way to determine that?
thanks again
JJ
Old May 20, 2009 | 12:18 AM
  #13
Mike Sigmond's Avatar
ROTM Coordinator
I would just rotate that plug wire boot so the filter does not sit on it. Dont most part stores have an aisle for 350 accessories?
Old May 20, 2009 | 12:41 AM
  #14
suzuki-guy's Avatar
You can buy a smaller Air cleaner assembly I had one on my 85.
Old May 24, 2009 | 5:38 PM
  #15
jjhearn's Avatar
OK. I ran a compression test today. well, I did it, so i am not sure how close I am. But, it ranged from 135 to 150. Keep in mind, I had never done this.
As soon as it quits raining, I am gonna go get some plugs, wires, etc.
Any suggestions on what I should do next? Other than a tune-up, I am lost.
Where can I find the compression ranges for the engine I have. My casting code is 3970014. But I can't seem to find anything related to what I am looking for.
thanks
JJ
Corliss010492
Mar 9, 2014 12:00 PM
C-Mos32
Sep 17, 2013 3:29 PM
Cynthia Morse
Aug 30, 2012 7:53 AM
87box
Aug 26, 2011 7:10 PM
