HHR This retro crossover vehicle combines the usefulness of a minivan with the size of a mid sized car.
Platform: Delta
Also Check out ChevyHHR.net
What gear oil for a 2006 manual transmission?
Old Aug 20, 2021 | 9:00 PM
Yasmataz's Avatar
Default What gear oil for a 2006 manual transmission?
I recently replaced my 5 speed manual 2.2l eco tech engine. Does anybody know what kind of gear oil it takes? Also wondering if that is the problem why I can't shift gears after driving about 5 blocks. My temperature gauge bounces as I'm speeding up, barely half way up, then drops to the bottom as I slow down then can't shift gears. I then pop the hood and it's pretty hot under the hood. I can shift gears again after about 5 minutes of letting it sit to cool down. Can anyone help me with what the problem is? Also my speedometer didn't seem to work at all.
Old Aug 20, 2021 | 11:23 PM
to clarify; you replaced the engine not the transmision....and now the trans doesn't shift properly. If yes....were the shift cables removed from the trans
Old Aug 21, 2021 | 9:30 PM
oilcanhenry's Avatar
Your transmission needs the synchromesh fluid, not 80-90 gear oil. You could even use the newer Dexron VI synchromesh fluid, if you wanted too.
I'd pay attention to what tech2 mentioned as well. He's a professional tech.
Old Aug 22, 2021 | 8:19 PM
Yasmataz's Avatar
Yes just replaced the engine not transmission. Yes the transmission cables were removed n put back on.
Old Aug 22, 2021 | 8:22 PM
Yasmataz's Avatar
Awesome thank you sir, I'll try it
dodginbulls
Aug 27, 2014 9:47 PM
eromore189
Mar 30, 2014 12:12 PM
lbcepe
Jun 27, 2010 8:18 AM
rfishbone
Jun 26, 2007 1:43 PM
