2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
06 Chevy impala completely dead need help
Old Oct 28, 2019 | 2:17 PM
Brittany Davenport's Avatar
Default 06 Chevy impala completely dead need help
I need to know what this wire goes to in my 06 Chevy impala please help!
Old Oct 29, 2019 | 12:28 PM
Irish_alley's Avatar
I'm here for the party
hard to say. will the car start? the wire being that thick i would assume it was something for high voltage like the ignition coil or something
Old Nov 2, 2019 | 6:26 PM
Frank3's Avatar
Hello Brittany, so you have a disconnected wire.... can you see (or show us) what the other end of that wire you are holding connects to? Maybe this can give us a clue.
Old Nov 3, 2019 | 2:25 PM
If it were high voltage then you wouldn't have an exposed quick-disconnect terminal on the end.
GM doesn't normally use QD terminals, so that tells me this is probably a mod, not a factory connection. Also the way the rubber gasket is crimped into the terminal is weird. Someone's been messing around.
Old Nov 21, 2019 | 5:18 PM
jso2378's Avatar
Looks like it could be a antenna cable.
idiazhd16
Nov 4, 2016 8:26 AM
kb3gup
Dec 1, 2014 9:52 PM
clintsy
Jun 5, 2012 11:22 PM
