2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
08 impala gear indicator
Old Jul 9, 2014 | 12:15 AM
08impala's Avatar
Default 08 impala gear indicator
On my dashboard of my 2008 Impala LT where my gear indicator is
P R N [D] 3 2 1 there should be a box around which gear my car is in. Well, recently that box disappeared. Also, to check some of your settings like oil life the car has to be in park or it will say " Feature available in park". I continue to get this message even while the car is in park ever since the box disappeared.
Old Jul 9, 2014 | 8:07 AM
Frank3's Avatar
Do you have a floor or column shift? My Tahoe started to have the same problem, if the shifter lever on the column did not return to the rest position after shifting I had the problem. When you shift out of park you pull the lever towards you. Returning to Park, I ended up pushing the lever away from me when in the park position. Maybe it was a switch going bad, but it has been working.
Old Jul 9, 2014 | 2:24 PM
Official GM Rep
Hi 08impala! Does the Feature Settings still show once you shift out of Park? Usually if the Feature Settings Menu is not available, FEATURE SETTINGS AVAILABLE IN PARK will display. Your dealership may be able to verify whether or not this has anything to do with the box disappearing from the gears. If you'd like to private message us your VIN and contact information we can work on looking more into this for you.
Amber N.
Chevrolet Customer Care
Old Jul 14, 2014 | 6:31 AM
08impala's Avatar
Also the cruise control and remote start went out at the same time.
Old Jul 14, 2014 | 8:44 AM
sledge.impy's Avatar
Check your fuses??
Old Jul 14, 2014 | 1:54 PM
Official GM Rep
I've sent you a private message, 08impala. I look forward to further discussing your vehicle concerns and assisting towards a resolution.
Amber N.
Old Sep 1, 2014 | 11:43 PM
rockemoremc's Avatar
Default Same car
Did you ever get car fixed if so what was the the problem and how much did it cost
Old Feb 19, 2021 | 4:51 PM
Dheim's Avatar
we are having this same issue. Any ideas?
Brightmo Quez
May 16, 2020 10:41 PM
bluelimo
1988 - 1998 (GMT400)
Jul 11, 2017 10:49 PM
Frederick J. Woodhouse
Sep 29, 2015 4:59 AM
mak1na
Apr 23, 2013 11:32 AM
mjpmin
May 18, 2010 12:53 PM
