2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2002 heater blower speed
Old May 1, 2010 | 2:43 PM
okie44e's Avatar
Default 2002 heater blower speed
i have a 2002 impala, the heater-a/c blower speeds only work on 3-4 speed 1-2 dont. i have found the blower motor under the dash below the glove box but anyone know where the resistors are? i think its a bad resistor but if anyone else has any ideas please let me know.
Old May 1, 2010 | 3:56 PM
capucine's Avatar
You have to buy a new block resistor. The one you will get is a better version than the older model. It is sealed. I had the same problem with my 03 impala and By replacing this block it work fine now. At the dealer it cost aprx 65$. Be prepare to have a rough time under the dash as it is very crowdy and tight to work in that small area. Get some proper tools like a flex handle for your socket as there is no room for the normal tools. Otherwise with the compact sockets set and flex drive it can be done by a human . Good luck
Old May 1, 2010 | 4:01 PM
capucine's Avatar
Sorry the location is just above the fan. Pull the carpet and rubber mat out of your way to have a better view. Like I said it can barely be done by human. Also I took the passager seat out of there so I could lay down on my back to have some room. The smaller your body is the better you will enjoy the work.
Old May 1, 2010 | 4:09 PM
okie44e's Avatar
ok thanks for the tip to remove the seat, it sure hurt trying to look under there, i will get the flex handle for sure and i think i found the block on ebay for 45 dollars, i appreciate the help
Old May 3, 2010 | 2:12 PM
HotSauce6226's Avatar
Impala Super Moderator
Blower Motor Resister
JUNIOR
Sep 6, 2015 2:54 PM
vanagon40
Dec 10, 2009 9:15 AM
94burbin
Jul 17, 2009 7:32 PM
rsaz
Sep 15, 2008 10:41 PM
wwotr
May 21, 2008 10:19 PM
