2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
No electrical power anywhere
Old Oct 3, 2019 | 8:09 PM
jso2378's Avatar
Default No electrical power anywhere
I have a 2013 impala limited that has no power anywhere. The only sign of power is the check engine light stays lit regardless if the key is in the ignition or not. The engine will turn over by jumping the starter relay but does not start. No interior or exterior lights and no gauge movement at all. I know the battery is good its brand new. I even tried using a jump box connected to the battery and nothing at all but the check engine light. Please help.
Old Oct 3, 2019 | 9:03 PM
always check fuses
Old Oct 3, 2019 | 9:46 PM
jso2378's Avatar
Checked all the fuses in the under hood fuse box yesterday with a test light. They are all good and have power. Fusible links all appear good also. I am wondering if I have a problem with the main ground but do not think the check engine light would be lit if that was the case. Do not think I would be able to turn the engine over by jumping the starter relay either.
Old Oct 4, 2019 | 6:15 AM
a55bruce's Avatar
Bad BCM ??
Everything is controlled by the BCM.
Check the connectors to the BCM and the fuse block.
Cycle the power... disconnect / reconnect the battery.
Old Oct 4, 2019 | 6:37 AM
jso2378's Avatar
Where is the BCM located?
Old Oct 5, 2019 | 6:38 AM
a55bruce's Avatar
https://www.impalaforums.com/audio-v...al-pinout.html
Old Oct 5, 2019 | 6:10 PM
Need to check near battery and along firewall for a mega fuse...
Old Oct 5, 2019 | 8:34 PM
jso2378's Avatar
Found the problem. Found this ground wire tucked in the fender skirt below the battery. Went and looked at my other impala and saw it grounds to the core support in front of the battery. As soon as I started tightening it I heard arcing and knew I had found the trouble. Everything works now. Thank you to everyone for your help.
Old Nov 20, 2019 | 5:32 PM
Michael Barton's Avatar
Pass loc bypass on a 2002 chevy impala ls with a 3.8
muggshots
Oct 20, 2021 7:16 PM
dspud2006
May 16, 2016 3:26 PM
510det
Feb 27, 2010 7:38 PM
byronrk
Sep 12, 2008 3:13 AM
chkihann
Jul 28, 2007 10:31 PM
