K5 Blazer 1969-1994
Platform: Truck, GMT 400
problems with carb and intake
Old Jan 15, 2013 | 11:52 AM
drblawnbuster's Avatar
Default problems with carb and intake
i bought my k10 with a stock 350with a q-jet 17081200 carb and a 14014432 GMCFM intake and have been havig alot of problems with back firing through the carb on hard acceleratiion and no power. is this a good set-up to be running? i know its not the stock set-up should i change something. it has a fresh tune-up,timing is correct,and the compression test checked out very good. could use some insiight
Old Jan 15, 2013 | 12:18 PM
kevinkpk's Avatar
Backfire through the carb is ignition/timming.
Old Jan 15, 2013 | 1:11 PM
what do you mean by igntion? the timing is right on just fixed that issue.
Old Jan 15, 2013 | 1:59 PM
kevinkpk's Avatar
backfire through the carb is timming.
Edwardsd1
Jun 6, 2012 11:44 AM
stlhedr29
Aug 4, 2010 10:06 PM
wilba504
Oct 22, 2008 9:35 AM
85chevy
Mar 20, 2008 7:17 PM
tryintodoit
Jan 5, 2007 11:59 AM
