Chevrolet Malibu
Instrument Cluster Problems
Old Aug 13, 2018 | 10:05 AM
Bilito's Avatar
Default Instrument Cluster Problems
We have a 2010 Malibu 4 cylinder we bought brand new.
The cluster went blank along with the gear selector light
First thing we did was to check Battery connections and the fuses, there is a cluster fuse in the truck and another one inside the car, they were OK. Tightened batt cables. Nothing.
Someone said the dimmer switch has caused some issues, so we got the plug off the dimmer switch and put it back on and yea the cluster came back to life, two days later it went blank again, I thought perhaps the cluster plug itself was dirty and took the dash apart, got the cluster out, unplugged and plugged it in a few times, turned the key on, the cluster came back to life. Cleaned all the connections with Deoxit Contact Cleaner and put everything back together, 4 days later it went blank again, the battery was the original that came with the car when we bought it new, so we got a new battery yesterday, installed that and the cluster came back to life again, this morning while the wife was driving to work the cluster went blank again.
What now?????
Old Aug 13, 2018 | 1:15 PM
oilcanhenry's Avatar
What now?????
Replace cluster dimmer switch.
Old Aug 13, 2018 | 3:08 PM
Bilito's Avatar
Hi Oil Can
How sure are you about the dimmer switch ?? What does the dimmer do with relation to the cluster other then dimming the lights?
My wife just went out and disconnected and then reconnected the battery and the cluster lit up and is working again, thought this piece of info might help.
Old Aug 14, 2018 | 10:20 AM
Hi Oil Can
What can happen is that if the dimmer switch is bad, disconnecting the battery allows it to cool down and work....but only for awhile.
Heck, the correct ACDelco switch is only $22 USD. No car ever made was perfect, and things wear out, just as we humans do.
Am I positive that that is your problem? No, but I am pretty good at guessing with the information I have at hand. You could pull it,
put it on a bench test with a multi-meter, if that would save you some money. Me I'd chuck it and put the new dimmer in.
Old Aug 14, 2018 | 10:36 AM
Bilito's Avatar
Thanks for the info, goona get a new switch.
Old Aug 22, 2018 | 4:23 PM
Bilito's Avatar
Update,, got the new instrument cluster dimmer switch on Mon Aug 20, installed same day, instrument cluster working, now it is wed evening aug 22 and cluster is still working , wife reports the lights are much brighter. looks like the dimmer switch was the problem.
Old Aug 23, 2018 | 6:48 AM
Bilito's Avatar
Last update, Switch still working on the ride to work, no further updates unless something happens, it appears that the instrument cluster switch was the culprit. The hardest part of the job was figuring how to get the switch out of the hidden brackets once the dash was opened up and we could access the switch, there is three torx screws to remove and once they are out and the bracket is off the dash it took us a while to find the hidden snaps that hold the switch in place on that bracket. New switch was pushed in and click, it was in place.
Old Aug 27, 2018 | 5:10 AM
Bilito's Avatar
IT"S DEAD AGAIN,
Wife got in the car this morning, instrument Cluster dead, we did not use it over the weekend so it appears the dimmer switch was not the problem.
Calling on all you Chevy guys, what else controls the power to the instrument cluster???? it all goes dead. Nothing works The panel is black, we disconnected and reconnected the Brand New Battery this morning hoping against hope that would cure the issue.
Everything else in the car works, it is as if the instrument cluster panel is disconnected, now what can cause that????
Frustrated in Miami........
Old Aug 28, 2018 | 2:49 PM
Bilito's Avatar
Thuis is frustrating, I have a problem and no one seems to be able to help me diagnose it.
I can order a rebuilt instrument cluster from the local auto parts store for around 150 or so plus a 100 core charge, the cluster is rebuilt by Dorman products.
The problem is I want to be sure that is the problem before I spend 150 for a part that may or may not fix the problem
The dimmer switch did not fix the problem
does anyone have any ideas?
Old Aug 28, 2018 | 5:42 PM
Sorry that your instrument panel is still giving you trouble, Bilito. I can only add that intermittent problems like yours, are difficult to diagnose. Might be a wiring issue or a bad ground, but frankly I simply dont know. It may be a defective unit too.
If you go the rebuild route I wouldn't use Dorman. They are okay for small parts, but they too can also fail. I am in no way affiliated with D&D Instruments, who happen to be one of the sponcers .of this forum, and have not yet had reason to use thier services, but if I did I would choose them over a Dorman rebuild. https://ddinstruments.com/auto-cluster-repair/
