Chevrolet Malibu
Let's try this again no start no crank funky stuff going on.
Old Sep 2, 2021 | 8:56 AM
  #11
there is a tsb for passenger seat wiring harness chaffing....this can bring down the bus. inspect the wiring. if you find nothing i will check into diagnostics tonight.
Old Sep 2, 2021 | 10:02 PM
  #12
post the engine size
u151b bcm lin b1 lost com with sunroof control module. Can't see this causing a no crank concern as the lin bus should not effect the other bus lines. Does the sunroof work?
u0121 Bcm lost comm with EBCM.
go in with your scan tool and see if you can view ebcm data. If not...check power and grd to the ebcm.
Old Oct 6, 2021 | 1:25 PM
  #13
Jonfromlocust's Avatar
When you said funky stuff going on that tells me you have a bad ground a computer cannot think with a bad ground check your ground you have several cab to frame battery to frame there are several on the vehicle but check the battery ground to the battery the ground to the frame to ground to the engine you have a ground problem guaranteed
Old Oct 6, 2021 | 1:26 PM
  #14
Fluffy Turtle
Aug 27, 2021 5:34 PM
Matt-K210
Apr 28, 2021 1:36 PM
ebcrosby
Astro
Jan 15, 2014 6:52 AM
eyeflyfish
Dec 27, 2008 6:50 AM
2000chevyprerunner
Nov 19, 2007 7:35 AM
