Chevrolet Malibu
Red hot brake rotor
Old Jan 14, 2024 | 7:09 AM
Steelshot16's Avatar
Default Red hot brake rotor
Friend of mine got a flat tire and drove it back home they called there dad to come help put on there spare that was also flat. They got a new tire for there wheel and put it on the next day and test drove it and noticed some smoke coming from there tire and that there rotor was red hot. They called me to come take a look at it and i could notice the rotor looked like it had some heat damage. I took it on a test drive and nothing seemed off after the drive the brakes wernt smoking nor red hot. I thought maybe the caliper was sticking so i took the wheel off and the caliper moves freely and the slide pins moved freely the brake line seemed fine the brake pads had some nasty cracks in it from getting hot but everything looked alright i put it back together. And they have been driving it for the past couple days with no problems no smoke or getting hot. Was curious of why the brake pads would stick just once but be fine after that.
Old Jan 14, 2024 | 5:01 PM
maybe someone drove off with parking brake on. I mean ... they don't even know how to change a tire.
Old Jan 14, 2024 | 6:02 PM
it happened on passenger side front wheel. After thinking about it, Im guessing the caliper is just starting to get stuck or the inside of the brake lines starting to deteriorate.thanks for reply.
Old Jan 14, 2024 | 7:02 PM
yup those flexible hoses can swell all the way shut, or air bubbles can expand the cylinder.
Please post the vehicle details next time.
Old Jan 15, 2024 | 8:53 AM
Moonwink's Avatar
I'd replace the brake hose as a precaution. I've had them work like a check valve. Once you step on the brakes, that caliper won't release.
angee
Feb 21, 2018 10:19 AM
er2cc
Nov 1, 2014 8:32 AM
upthereinthesky
Oct 28, 2014 5:00 PM
ONLYNAMRICA
Jan 25, 2011 11:32 PM
bassrat31u
Jun 28, 2008 9:44 AM
