Platform: A-, G-, & W-body
2000 Monte Carlo SS AutoTrans overdrive shifts hard/jerky
Old Sep 20, 2008 | 2:27 PM
sunshine219's Avatar
Default 2000 Monte Carlo SS AutoTrans overdrive shifts hard/jerky
I have had this car since 2002 and the problem started this summer. My transmissionshifts very hard/jerky thru up shifting from 30mph to 45mph and only after it has been driven about 30 milesperating temp. I changed the trans filter, fluidand added Lukas transmission fix... still does it. It seems to be the overdrive overheating. My question is there a sensor/controller that could be doing this? What controls the overdrive? Any advise will be welcomed!
Old Jan 4, 2009 | 3:27 PM
1969 ZL1's Avatar
Default RE: 2000 Monte Carlo SS AutoTrans overdrive shifts hard/jerky
You have two solenoids in the transmission that control the shift points. Both are inside the transmission. One is on the side you can get to by splitting the case and the other is up inside the transmission meaning it will have to be taken out for replacement.
Is it the one-two shift or the two-three shift?
Old Jan 8, 2009 | 7:28 PM
First thank you so much for the assistance. Sadly it is the one to two and the two to three, does this mean both sensors or even more problems?
snake91876
Oct 13, 2012 3:41 PM
SS Boyy
Feb 21, 2011 2:09 PM
stephschevy
Feb 6, 2010 10:59 PM
jiggsy
Sep 29, 2009 6:35 PM
TRWFan
Mar 24, 2009 10:07 PM
