Platform: A-, G-, & W-body
Front end makes 'Popping' noise
Old Dec 11, 2009 | 6:53 AM
unboundtrucker's Avatar
Default Front end makes 'Popping' noise
I have a noise in the front end of my 2000 Lumina, It sounds like it's coming from the driver's side. I changed both strut cartrages, both top mounts, both ball joints, both outer tie rod ends. (the car has 250,000 miles on it so it was due 0_o ) I then had it aligned. The noise is still there, is there a front end tech out there who could advise me as to what to look for next?
Old Dec 11, 2009 | 7:29 AM
I forgot to say this noise only occurs when I turn the wheel.
Old Dec 15, 2009 | 5:43 PM
montemadness04's Avatar
that noise is caused from your Intermediate Steering Shaft or your ISS.. it needs to be lubricated and possibly replaced... its fairly easy to lubricate and many people find that a simple lubrication may fix the issue... under your steering wheel there is a boot you can bring down to gain access to the ISS... you can use a spray lubricant like a silicone spray or white lithium grease with a straw tube to spray it into the area... this is a fairly common issue on the Wbody cars although GM never did a recall on it but I do know that GM's Technical Service Bulletin does call for replacement however like I said previously many people have found the problem has been fixed by simple lubrication of the joint
Old Dec 16, 2009 | 7:24 AM
Thanks for the response.The Chilton manual does not show an Intermediate Steering Shaft on this car. When I finally had some help I discovered that the noise is coming from the spring on the strut, the lower mount is catching some how and when there's enough torque it finally releases and that's where the sound is coming from. That lower spring mount is supposed to turn on a bearing. I ordered the part and soon will have the complete strut assembly on the bench, oh fun oh joy. Happy Wrenchin' Guy's n Gal's and thank's for the awsome site. : D
07Chevyboy
Mar 30, 2015 9:31 PM
jensenracing77@yahoo.com
May 11, 2011 5:41 PM
cox222
Jul 19, 2010 12:47 AM
catch22
Apr 7, 2010 3:45 AM
allyourbase
Jul 12, 2009 6:43 PM
