Platform: A-, G-, & W-body
how many psi do lumina injectors run
Old Oct 30, 2011 | 9:00 PM
ryans01z28's Avatar
Default how many psi do lumina injectors run
I'm building my own fuel injector cleaner and want to know how many psi it takes to open the injectors. Thanks in advance
Old Oct 31, 2011 | 8:38 AM
ryans01z28's Avatar
Wow no one knows??
Old Oct 31, 2011 | 11:30 AM
EinST's Avatar
No, it's more like you don't seem to understand what you're asking. Are you trying to pressurize the fuel injector on the fuel supply side until the fuel injector sprays? What do you think the electrical connector is for?
Old Oct 31, 2011 | 2:32 PM
ryans01z28's Avatar
Well you c I want to know how many psi they can take so I don't ovr pressure them and wreck them if that's possable.
Old Oct 31, 2011 | 6:30 PM
EinST's Avatar
Without knowing what exactly it is that you're rigging up, I suggest not to exceed the nominal key-on-engine-off fuel pressure of the vehicle the particular injectors came out of.
Old Nov 12, 2011 | 4:15 PM
ryans01z28's Avatar
i built a on the rail fuel injector cleaner like the otc cleaner (see pic). im guessing i could run the pressure at the same as the fuel pump pressure or slightly below
Old Nov 12, 2011 | 6:49 PM
EinST's Avatar
I don't know what you mean by "fuel pump pressure" but if you were to disconnect and block the fuel return line, you shouldn't exceed the nominal KOEO fuel pressure.
Old Nov 12, 2011 | 7:03 PM
ryans01z28's Avatar
"Fuel pump pressure"= 41-47psi I didn't mean to confuse you i cleaned the fuel injectors and my problem still exists please see my other post on the problem
shayandude
Jun 4, 2022 4:10 AM
Wakko
Apr 7, 2014 10:15 AM
Role Chapa
May 9, 2012 9:48 AM
Ranger#83
Jul 16, 2010 8:56 AM
