1994 engine rebuild and swap, can't get rid of spark knock
Old Oct 28, 2024 | 6:50 PM
Sltlystpd's Avatar
Default 1994 engine rebuild and swap, can't get rid of spark knock
So I did my first rebuild on a 5.7 350. To be clear, this is my first time havinf rebuilt and engine, and i did as much in depth research as i could aswell as getting advice from people who know eay more than me. The only changes I made from stock were 10:1 compression high compression pistons from a camaro of the same year, and a stage 2 cam. According to everything I've read and people I've talked to, this 2 changes should have been fine. However, I have an intermittent knocking that as best we can all figure is spark knock seeings as the entire bottom end was gauged, torqued to spec, and rotated a dozen times to make sure everything cleared and was tight. No matter how much I mess with the timing I can't get the knock to go away, I can get it to lessen, even go away briefly, but it always comes back. Today I was told the cam is the problem, and that the computer isn't flashed for the higher compression. So now I'm trying to figure out if I can swap my OBD 1 ecm for a camaro ecm or maybe have the ecm re-flashed for a higher compression engine. The only thing I haven't done is pull the wire that runs to the distributor and reset the timing that way, seeings as I just today was able to find where they hit the disconnect for it. Other than that I'm honestly at a total loss at this point.
bpwheelan
1988 - 1998 (GMT400)
Feb 24, 2019 12:13 PM
ill4na8na2
Feb 9, 2015 10:36 AM
davec66
K5 Blazer
Dec 28, 2010 11:50 AM
johngodwin30
Jul 28, 2010 3:54 PM
windpower79106
Nov 16, 2006 1:36 PM
