S-10 & Blazer 1982-2005
1999 blazer cranks but won't start
Old May 4, 2016 | 11:10 AM
  #21
arias57's Avatar
Try replacing the ignition control module. That's what happened to mine and I finally got it started. You can get them for about 10 bucks on ebay, otherwise about 30 to 50 elsewhere. Good luck.
Old May 4, 2016 | 11:18 AM
  #22
arias57's Avatar
Try replacing the Ignition Control Module. You can get them on eBay for about $10 bucks or $30 to $50 elsewhere. But sounds like your fuel pump could be failing. Best trick to replace it is to cut a door through the trunk above the fuel tank to access the fuel pump without having to remove the gas tank. Good luck.
drzen99@yahoo.com
Jan 13, 2019 9:38 PM
Ron-tx
Mar 30, 2016 9:22 AM
bigbensteel
Oct 13, 2010 8:33 PM
PrecisionAuto
Nov 24, 2008 11:42 AM
elviejo59
Aug 6, 2008 8:14 PM
