S-10 & Blazer 1982-2005
97 4.3 vortec po300 of death please help
Old Dec 9, 2012 | 11:02 AM
daddydec21's Avatar
Default 97 4.3 vortec po300 of death please help
Hello new here to the forum. I am haveing po300 problems. started off as a cyl 1 and 2 misfire, replaced coil, plugs, wires, cap and rotor (acdelco), maf, tps, distributor, checked for vaccum leak by spraying every inch of the motor, cyl 1 was misfireing at 96 misfires per cycle and cyl 2 was 79 misfires per cycle, now i have a cyl 3 misfire at 185 per cycle, checked fuel have 64 psi with key on and 55-60 with it running, also did a injector test and all the injector pressure to 65 and go to 30psi t the same time, replaced with new cam sensor, new egr reading on my scanner at 1500rpms my cam would go to -17 degrees so i resat the timing at 0 degrees and it seems to running a little worse. Starts with no trouble but has a small rumble seems like it has a radical cam , If you go to pull out i stumbles a bit but runs fine with higher rpm. misfire counter goes down between 20 and 65 at higher rpms
check engine light flashes unless i am on the gas at around 12 1300 rpms and higher
here the specs from my scanner,.
rpm 700
tps 0.57
b1s1 495-600 MV fluctuates constantly
B2B1 200-550 MV fluctuates constantly
B1S3 200-740 MV fluctuates constantly
A/F RATIO IS 14.7
MAF 7.5
BARO (KPA) 95
MAP 2.05 V 49(KPA)
COOLANT 94DEG CELSIUS
INTAKE AIR 16 DEG CELSIUS 2.66V
IAC 84
DESIRED IAC 84
DESIRED IDLE 650
IGNITION 13.5 VOLTS
MISFIRE CYL 3 184 PER CYCLE
KNOCK 4.65
SPARK ADVANCED 22
KNOCK RETARD IS 0
CAM RETARD 0
CAM RETARD CHANGES TO -17 AROUND 1300 RPMS AND SLIGHT TO NO MISFIRES AFTER 1200 RPMS
B2S1 SWITCHING FROM LEAN TO RICH CONSTANTLY
egr 0.76
Old Dec 9, 2012 | 2:17 PM
kevinkpk's Avatar
I'd suggest set the timming to what it should be, and give it a hefty dose of injector cleaner or sea foam
Old Dec 9, 2012 | 6:48 PM
daddydec21's Avatar
an specific way to do that. that works the best?
Old Dec 9, 2012 | 7:11 PM
kevinkpk's Avatar
Is this not just an hei distributor?
Old Dec 9, 2012 | 9:17 PM
daddydec21's Avatar
vortec plug wires come out the side of the cap not in the top
Old Dec 12, 2012 | 4:44 PM
daddydec21's Avatar
ok so after ripping everything apart i come to find someone changed the spyder already........... took it to a local shop they cleaned it n tested it it was fine put it in and still same thing cyl 3 misfire?????????? what next
Old Mar 13, 2015 | 11:15 PM
bat man1950's Avatar
Default batman1950
po300 tps over fuel ing I did alot of what u did oz sensers a lot of thangs cel on when idle or when u let up on gas when I step onit it when flash ing it went out
Old Mar 7, 2016 | 7:28 PM
engine55's Avatar
Look at the posts inside your distributor cap. If you see signs of excessive arcing you have a problem with the gears at the bottom of your distributor. It’s a common problem in high mileage Vortec engines. It always leads to random misfires. Go to www.vortecrighttime.com and get their rotor. They guarantee it will fix random misfires permanently. I had the same problems with my last two Vortec equipped vehicles. The new rotor completely fixed it. I got a new distributor. It worked for about 6 months and the misfires came back even worse.
syuchimiuk
Mar 20, 2011 10:54 AM
brocnizer
Jun 7, 2009 8:28 PM
bigfry
May 31, 2008 5:25 PM
gcahal_az
Feb 26, 2007 12:47 AM
