S-10 & Blazer 1982-2005
Backup / Reverse Lights don't work...
Old Jun 22, 2011 | 10:11 AM
jimthesoundman's Avatar
Default Backup / Reverse Lights don't work...
I have a 2003 S-10 Extended Cab 4-cyl Automatic.
The reverse lights have quit working. All other lights seem to be working okay.
Does anyone know where the switch is that needs to be replaced?
Is it on the steering column or is it attached to the transmission?
Thanks in advance for any help.
JIM
Old Jun 22, 2011 | 12:38 PM
EinST's Avatar
Welcome to the forum. The backup lamp switch is part of the park/neutral position (PNP) switch mounted on the transmission. Have you checked the fuses underhood? There should be one 25A main fuse upstream of the switch and then one 15A fuse upstream of the backup lamps.
Old Jun 23, 2011 | 10:38 AM
So can I assume the switch is good? If the switch was bad, then the vehicle would think the transmission was not in park and I wouldn't be able to start it, correct?
Old Jun 23, 2011 | 11:07 AM
EinST's Avatar
No, you cannot assume that. The PNP switch circuit and backup lamp circuit are electrically separate.
Old Oct 24, 2014 | 8:59 AM
bachel1's Avatar
Default Back-up lights not working
Working on S10 2000 back up lights. New switch and receptacle, both working and getting juice. Fuse is fine.
Where could the problem be?
Old Oct 22, 2020 | 11:23 PM
James Eury's Avatar
Default Location of
JIM
backup light switch is on the side of the transmission
Old Apr 7, 2021 | 3:18 PM
Larry'strailblazer's Avatar
Did you ever fix your back-up light problem? If so , what did it turn out to be?
Thanks, Larry
Old Apr 13, 2021 | 5:30 PM
Dartman's Avatar
Default In the Dark
Hello check all the bulbs the sockets all wires and grounds. Check for power might not be the switch after all. I had good bulbs loose contact those little wires needed to be pulled back till it pinched better , the same happened with sockets the fix . Battery disconnected . Had to use a pick to pull the contacts into near touching each other installed bulb no more problems
Old Apr 14, 2021 | 7:29 AM
Thanks for the reply, but this thread is ten years old, and that S-10 is long gone. I hope your reply will help someone else out with the same problem.
Db9915
1988 - 1998 (GMT400)
Jun 9, 2018 9:06 PM
K Mack
Dec 22, 2017 4:13 AM
capezig
Nov 13, 2015 6:05 PM
suzuki-guy
May 19, 2009 11:12 PM
00z24
Jun 18, 2006 5:36 PM
