S-10 & Blazer 1982-2005
Emmision system problems
Old Mar 5, 2011 | 8:29 PM
pallettman's Avatar
Default Emmision system problems
Just joined the forum. Hope you guys can help! I have a 2003 2.2L base truck. Engine light came on. Read the code 410. Said my smog pump or valves had a problem. Checked pump and valves. Cleaned valves, pump works fine. What else should I check? Except for the engine light, it runs great, no problems at all. Thanks in advance. Looking for good information to enhance my truck.
Old Mar 6, 2011 | 10:01 AM
EinST's Avatar
P0410 means the PCM didn't detect the extra air from the AIR pump, based on the O2 sensor readings. Check the AIR plumbing to make sure there's no blockage or leaks.
Old Mar 6, 2011 | 8:21 PM
lynnboy021's Avatar
i had the same code and i changed bank one and bank 2 o2 and it went away
Old Mar 6, 2011 | 8:22 PM
pallettman's Avatar
When you say AIR plumbing, what exactly do you mean? I followed all the hoses and lines from the air pump. They all seem fine. I took off all the factory hose clamps and put on new ones. One other thing, after I cleaned everything, I had the codes reset. I didn't get another code until after approx. 100 miles. Kinda stumped.
Old Mar 6, 2011 | 8:37 PM
lynnboy021's Avatar
CIRCUIT DESCRIPTION
The secondary air injection (AIR) system is designed to reduce exhaust emissions during engine starts. The powertrain control module (PCM) activates the AIR system by supplying a ground to the AIR pump relay. This action energizes the AIR pump and the vacuum control solenoid, applying vacuum to the AIR shut-off valve, opening the valve. The AIR pump then forces air past the shut-off valve, through the pipes/hoses and the exhaust check valve into the exhaust system to accelerate catalyst operation. When inactive, the shut-off valve prevents airflow in both directions. The PCM will perform a passive test while the AIR system is performing normally. During the test the PCM monitors the O2S voltages, expecting a drop below 100 mV , approaching near 0 mV . The PCM expects the short term fuel trim (FT) to increase at the same time. If the test fails or is inconclusive, the PCM will run up to 3 diagnostic active tests using the O2S voltage parameter and short term FT parameter to verify the system operation. When the PCM detects an insufficient O2S response, DTC P0410 sets.
CONDITIONS FOR RUNNING THE DTC
  • DTCs P0105, P0107, P0108, P0112, P0113, P0122, P0123, P0130, P0131, P0132, P0133, P0134, P0171, P0172, P0300, P0301-P0304, P0341, P0506, P0507, P0601, P0602, are not set.
  • The AIR system is commanded ON for more than 20 seconds .
  • The intake air temperature (IAT) is between 1-151°C (32-302°F) .
  • The engine coolant temperature (ECT) is between 5-114°C (41-230°F) .
  • The battery voltage is more than 11.0 volts .
  • The engine run time is more than 200 seconds .
  • The vehicle is operating in fuel trim cell of 16 or 17.
  • The throttle position (TP) sensor changes less than 5 percent .
  • The manifold absolute pressure (MAP) sensor is less than 30 kPa .
  • The injector base pulse width is more 0.650 ms .
  • The engine speed is more than 1,150 RPM for automatic transmissions.
  • The engine speed is more than 1,000 RPM for manual transmissions.
CONDITIONS FOR SETTING THE DTC
The control module does not detect that the O2S is less than 50 mV for 1 second during a 3 second active test for 3 consecutive active tests.
ACTION TAKEN WHEN THE DTC SETS
  • The control module illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
  • The control module records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the control module stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the control module records the operating conditions at the time of the failure. The control module writes the operating conditions to the Freeze Frame and updates the Failure Records.
CONDITIONS FOR CLEARING THE MIL/DTC
  • The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
  • A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
  • A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
  • Clear the MIL and the DTC with a scan tool.
DIAGNOSTIC AIDS
  • An AIR solenoid stuck open or leaking vacuum may hold the shut-off valve open. An audible exhaust noise may be heard through the AIR pump inlet hose. This condition may not set a code and may cause fuel trims to indicate high percent at an idle.
  • Verify proper connections of the vacuum hoses. Reversed connections at the AIR solenoid may cause the AIR shut-off valve to stick open.
  • Low system airflow may cause this DTC to set.
  • Excessive exhaust system back-pressure may cause this DTC to set.
  • An intermittent may be caused by any of the following conditions:
  • Pinched, restricted, split, or damaged pipes/hoses or vacuum lines
  • Restrictions in the AIR pump inlet hose
  • Damaged contacts in the AIR pump relay-Tap on the AIR pump relay to attempt to duplicate an intermittent condition.
  • Heat damage to the AIR crossover hose may indicate an exhaust check valve failure.
  • Water or debris ingested into the AIR pump may cause this DTC to set.
  • Observe the Freeze Frame/Failure Records to see what conditions set P0410.
Thoroughly inspect any circuits that are suspected of causing the intermittent condition. Refer to Diagnostic Aids for Circuit Testing and Wiring Repair Procedures.
If a repair is necessary, refer to Diagnostic Aids for circuit Testing and Wiring Repair Procedures
Old Mar 6, 2011 | 8:39 PM
lynnboy021's Avatar
TEST DESCRIPTION
<SCRIPT language=JavaScript> <!--var LOWmap156491514 = '<map Name = "map156491514"><area coords="480, 144, 528, 155" href="http://www.alldatapro.com/alldata/PRO~V207882618~C42602~R0~OD~N/0/89012112/94695002/94695157/119125426/34853741/34857029/34857030/34857663/122908437"></map>'var HIGHmap156491514 = '<map Name = "map156491514"><area coords="960, 288, 1057, 310" href="http://www.alldatapro.com/alldata/PRO~V207882618~C42602~R0~OD~N/0/89012112/94695002/94695157/119125426/34853741/34857029/34857030/34857663/122908437"></map>'// --> </SCRIPT><SCRIPT language=JavaScript> <!--document.write(LOWmap156491514);// --> </SCRIPT><MAP name=map156491514><AREA href="http://www.alldatapro.com/alldata/PRO~V207882618~C42602~R0~OD~N/0/89012112/94695002/94695157/119125426/34853741/34857029/34857030/34857663/122908437" coords="480, 144, 528, 155"></MAP><TABLE border=0 cellSpacing=0 cellPadding=0 width="90%" align=center><TBODY><TR><TD><TABLE border=1 cellSpacing=0 cellPadding=0 width=560><TBODY><TR><TD bgColor=#ccffcc width=560 align=middle>Steps 1-2</TD></TR><TR><TD></TD></TR></TBODY></TABLE></TD></TR><SCRIPT language=JavaScript> <!--var CAPTION156491514 = "Steps 1-2";// --> </SCRIPT><TR><TD><TABLE border=0 cellSpacing=0 cellPadding=2 width=560 align=left><TBODY><TR><TD><FORM method=post action="javascript:Zoom('/alldata/PRO~V207882618~C42602~R0~OB0~P2R0H~N/0/89012112/94695002/94695157/119125426/34853741/34857029/34857030/34857663/122915129/105258193/159346059/164572817/156491514', 1, 1120, 602, 'ZoomWin', CAPTION156491514, 'map156491514', HIGHmap156491514);"><INPUT value=Zoom type=submit></FORM></TD><SCRIPT language=JavaScript> <!--var HIGHNONE = '';var CAPTION156491514 = "Steps 1-2";// --> </SCRIPT><TD><FORM method=post action="javascript:SizedForPrint('/alldata/PRO~V207882618~C42602~R0~OB0~P2R0X~N/0/89012112/94695002/94695157/119125426/34853741/34857029/34857030/34857663/122915129/105258193/159346059/164572817/156491514', 1, 650, 349, 'ZoomWin', CAPTION156491514, 'NONE', HIGHNONE);"><INPUT value="Sized for Print" type=submit></FORM></TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
<SCRIPT language=JavaScript> <!--var HIGHNONE = '';var LOWNONE = '';// --> </SCRIPT><TABLE border=0 cellSpacing=0 cellPadding=0 width="90%" align=center><TBODY><TR><TD><TABLE border=1 cellSpacing=0 cellPadding=0 width=568><TBODY><TR><TD bgColor=#ccffcc width=568 align=middle>Steps 3-7</TD></TR><TR><TD></TD></TR></TBODY></TABLE></TD></TR><SCRIPT language=JavaScript> <!--var CAPTION102929017 = "Steps 3-7";// --> </SCRIPT><TR><TD><TABLE border=0 cellSpacing=0 cellPadding=2 width=568 align=left><TBODY><TR><TD><FORM method=post action="javascript:Zoom('/alldata/PRO~V207882618~C42602~R0~OB0~P2R0H~N/0/89012112/94695002/94695157/119125426/34853741/34857029/34857030/34857663/122915129/105258193/159346059/164572817/102929017', 1, 1136, 1314, 'ZoomWin', CAPTION102929017, 'NONE', HIGHNONE);"><INPUT value=Zoom type=submit></FORM></TD><SCRIPT language=JavaScript> <!--var HIGHNONE = '';var CAPTION102929017 = "Steps 3-7";// --> </SCRIPT><TD><FORM method=post action="javascript:SizedForPrint('/alldata/PRO~V207882618~C42602~R0~OB0~P2R0X~N/0/89012112/94695002/94695157/119125426/34853741/34857029/34857030/34857663/122915129/105258193/159346059/164572817/102929017', 1, 650, 751, 'ZoomWin', CAPTION102929017, 'NONE', HIGHNONE);"><INPUT value="Sized for Print" type=submit></FORM></TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
<SCRIPT language=JavaScript> <!--var HIGHNONE = '';var LOWNONE = '';// --> </SCRIPT><TABLE border=0 cellSpacing=0 cellPadding=0 width="90%" align=center><TBODY><TR><TD><TABLE border=1 cellSpacing=0 cellPadding=0 width=560><TBODY><TR><TD bgColor=#ccffcc width=560 align=middle>Steps 8-11</TD></TR><TR><TD></TD></TR></TBODY></TABLE></TD></TR><SCRIPT language=JavaScript> <!--var CAPTION102929018 = "Steps 8-11";// --> </SCRIPT><TR><TD><TABLE border=0 cellSpacing=0 cellPadding=2 width=560 align=left><TBODY><TR><TD><FORM method=post action="javascript:Zoom('/alldata/PRO~V207882618~C42602~R0~OB0~P2R0H~N/0/89012112/94695002/94695157/119125426/34853741/34857029/34857030/34857663/122915129/105258193/159346059/164572817/102929018', 1, 1120, 1060, 'ZoomWin', CAPTION102929018, 'NONE', HIGHNONE);"><INPUT value=Zoom type=submit></FORM></TD><SCRIPT language=JavaScript> <!--var HIGHNONE = '';var CAPTION102929018 = "Steps 8-11";// --> </SCRIPT><TD><FORM method=post action="javascript:SizedForPrint('/alldata/PRO~V207882618~C42602~R0~OB0~P2R0X~N/0/89012112/94695002/94695157/119125426/34853741/34857029/34857030/34857663/122915129/105258193/159346059/164572817/102929018', 1, 650, 615, 'ZoomWin', CAPTION102929018, 'NONE', HIGHNONE);"><INPUT value="Sized for Print" type=submit></FORM></TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
<SCRIPT language=JavaScript> <!--var HIGHNONE = '';var LOWNONE = '';// --> </SCRIPT><TABLE border=0 cellSpacing=0 cellPadding=0 width="90%" align=center><TBODY><TR><TD><TABLE border=1 cellSpacing=0 cellPadding=0 width=560><TBODY><TR><TD bgColor=#ccffcc width=560 align=middle>Steps 12-13</TD></TR><TR><TD></TD></TR></TBODY></TABLE></TD></TR><SCRIPT language=JavaScript> <!--var CAPTION102929019 = "Steps 12-13";// --> </SCRIPT><TR><TD><TABLE border=0 cellSpacing=0 cellPadding=2 width=560 align=left><TBODY><TR><TD><FORM method=post action="javascript:Zoom('/alldata/PRO~V207882618~C42602~R0~OB0~P2R0H~N/0/89012112/94695002/94695157/119125426/34853741/34857029/34857030/34857663/122915129/105258193/159346059/164572817/102929019', 1, 1120, 936, 'ZoomWin', CAPTION102929019, 'NONE', HIGHNONE);"><INPUT value=Zoom type=submit></FORM></TD><SCRIPT language=JavaScript> <!--var HIGHNONE = '';var CAPTION102929019 = "Steps 12-13";// --> </SCRIPT><TD><FORM method=post action="javascript:SizedForPrint('/alldata/PRO~V207882618~C42602~R0~OB0~P2R0X~N/0/89012112/94695002/94695157/119125426/34853741/34857029/34857030/34857663/122915129/105258193/159346059/164572817/102929019', 1, 650, 543, 'ZoomWin', CAPTION102929019, 'NONE', HIGHNONE);"><INPUT value="Sized for Print" type=submit></FORM></TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
<SCRIPT language=JavaScript> <!--var HIGHNONE = '';var LOWNONE = '';// --> </SCRIPT><TABLE border=0 cellSpacing=0 cellPadding=0 width="90%" align=center><TBODY><TR><TD><TABLE border=1 cellSpacing=0 cellPadding=0 width=568><TBODY><TR><TD bgColor=#ccffcc width=568 align=middle>Steps 14-16</TD></TR><TR><TD></TD></TR></TBODY></TABLE></TD></TR><SCRIPT language=JavaScript> <!--var CAPTION102929020 = "Steps 14-16";// --> </SCRIPT><TR><TD><TABLE border=0 cellSpacing=0 cellPadding=2 width=568 align=left><TBODY><TR><TD><FORM method=post action="javascript:Zoom('/alldata/PRO~V207882618~C42602~R0~OB0~P2R0H~N/0/89012112/94695002/94695157/119125426/34853741/34857029/34857030/34857663/122915129/105258193/159346059/164572817/102929020', 1, 1136, 1341, 'ZoomWin', CAPTION102929020, 'NONE', HIGHNONE);"><INPUT value=Zoom type=submit></FORM></TD><SCRIPT language=JavaScript> <!--var HIGHNONE = '';var CAPTION102929020 = "Steps 14-16";// --> </SCRIPT><TD><FORM method=post action="javascript:SizedForPrint('/alldata/PRO~V207882618~C42602~R0~OB0~P2R0X~N/0/89012112/94695002/94695157/119125426/34853741/34857029/34857030/34857663/122915129/105258193/159346059/164572817/102929020', 1, 650, 767, 'ZoomWin', CAPTION102929020, 'NONE', HIGHNONE);"><INPUT value="Sized for Print" type=submit></FORM></TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
<SCRIPT language=JavaScript> <!--var HIGHNONE = '';var LOWNONE = '';// --> </SCRIPT><TABLE border=0 cellSpacing=0 cellPadding=0 width="90%" align=center><TBODY><TR><TD><TABLE border=1 cellSpacing=0 cellPadding=0 width=560><TBODY><TR><TD bgColor=#ccffcc width=560 align=middle>Steps 17-19</TD></TR><TR><TD></TD></TR></TBODY></TABLE></TD></TR><SCRIPT language=JavaScript> <!--var CAPTION102929021 = "Steps 17-19";// --> </SCRIPT><TR><TD><TABLE border=0 cellSpacing=0 cellPadding=2 width=560 align=left><TBODY><TR><TD><FORM method=post action="javascript:Zoom('/alldata/PRO~V207882618~C42602~R0~OB0~P2R0H~N/0/89012112/94695002/94695157/119125426/34853741/34857029/34857030/34857663/122915129/105258193/159346059/164572817/102929021', 1, 1120, 1107, 'ZoomWin', CAPTION102929021, 'NONE', HIGHNONE);"><INPUT value=Zoom type=submit></FORM></TD><SCRIPT language=JavaScript> <!--var HIGHNONE = '';var CAPTION102929021 = "Steps 17-19";// --> </SCRIPT><TD><FORM method=post action="javascript:SizedForPrint('/alldata/PRO~V207882618~C42602~R0~OB0~P2R0X~N/0/89012112/94695002/94695157/119125426/34853741/34857029/34857030/34857663/122915129/105258193/159346059/164572817/102929021', 1, 650, 642, 'ZoomWin', CAPTION102929021, 'NONE', HIGHNONE);"><INPUT value="Sized for Print" type=submit></FORM></TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
<SCRIPT language=JavaScript> <!--var HIGHNONE = '';var LOWNONE = '';// --> </SCRIPT><TABLE border=0 cellSpacing=0 cellPadding=0 width="90%" align=center><TBODY><TR><TD><TABLE border=1 cellSpacing=0 cellPadding=0 width=560><TBODY><TR><TD bgColor=#ccffcc width=560 align=middle>Steps 20-22</TD></TR><TR><TD></TD></TR></TBODY></TABLE></TD></TR><SCRIPT language=JavaScript> <!--var CAPTION102929022 = "Steps 20-22";// --> </SCRIPT><TR><TD><TABLE border=0 cellSpacing=0 cellPadding=2 width=560 align=left><TBODY><TR><TD><FORM method=post action="javascript:Zoom('/alldata/PRO~V207882618~C42602~R0~OB0~P2R0H~N/0/89012112/94695002/94695157/119125426/34853741/34857029/34857030/34857663/122915129/105258193/159346059/164572817/102929022', 1, 1120, 1353, 'ZoomWin', CAPTION102929022, 'NONE', HIGHNONE);"><INPUT value=Zoom type=submit></FORM></TD><SCRIPT language=JavaScript> <!--var HIGHNONE = '';var CAPTION102929022 = "Steps 20-22";// --> </SCRIPT><TD><FORM method=post action="javascript:SizedForPrint('/alldata/PRO~V207882618~C42602~R0~OB0~P2R0X~N/0/89012112/94695002/94695157/119125426/34853741/34857029/34857030/34857663/122915129/105258193/159346059/164572817/102929022', 1, 650, 785, 'ZoomWin', CAPTION102929022, 'NONE', HIGHNONE);"><INPUT value="Sized for Print" type=submit></FORM></TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
<SCRIPT language=JavaScript> <!--var HIGHNONE = '';var LOWNONE = '';// --> </SCRIPT><TABLE border=0 cellSpacing=0 cellPadding=0 width="90%" align=center><TBODY><TR><TD><TABLE border=1 cellSpacing=0 cellPadding=0 width=560><TBODY><TR><TD bgColor=#ccffcc width=560 align=middle>Steps 23-25</TD></TR><TR><TD></TD></TR></TBODY></TABLE></TD></TR><SCRIPT language=JavaScript> <!--var CAPTION102929023 = "Steps 23-25";// --> </SCRIPT><TR><TD><TABLE border=0 cellSpacing=0 cellPadding=2 width=560 align=left><TBODY><TR><TD><FORM method=post action="javascript:Zoom('/alldata/PRO~V207882618~C42602~R0~OB0~P2R0H~N/0/89012112/94695002/94695157/119125426/34853741/34857029/34857030/34857663/122915129/105258193/159346059/164572817/102929023', 1, 1120, 1250, 'ZoomWin', CAPTION102929023, 'NONE', HIGHNONE);"><INPUT value=Zoom type=submit></FORM></TD><SCRIPT language=JavaScript> <!--var HIGHNONE = '';var CAPTION102929023 = "Steps 23-25";// --> </SCRIPT><TD><FORM method=post action="javascript:SizedForPrint('/alldata/PRO~V207882618~C42602~R0~OB0~P2R0X~N/0/89012112/94695002/94695157/119125426/34853741/34857029/34857030/34857663/122915129/105258193/159346059/164572817/102929023', 1, 650, 725, 'ZoomWin', CAPTION102929023, 'NONE', HIGHNONE);"><INPUT value="Sized for Print" type=submit></FORM></TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
<SCRIPT language=JavaScript> <!--var HIGHNONE = '';var LOWNONE = '';// --> </SCRIPT><TABLE border=0 cellSpacing=0 cellPadding=0 width="90%" align=center><TBODY><TR><TD><TABLE border=1 cellSpacing=0 cellPadding=0 width=560><TBODY><TR><TD bgColor=#ccffcc width=560 align=middle>Steps 26-30</TD></TR><TR><TD></TD></TR></TBODY></TABLE></TD></TR><SCRIPT language=JavaScript> <!--var CAPTION102929024 = "Steps 26-30";// --> </SCRIPT><TR><TD><TABLE border=0 cellSpacing=0 cellPadding=2 width=560 align=left><TBODY><TR><TD><FORM method=post action="javascript:Zoom('/alldata/PRO~V207882618~C42602~R0~OB0~P2R0H~N/0/89012112/94695002/94695157/119125426/34853741/34857029/34857030/34857663/122915129/105258193/159346059/164572817/102929024', 1, 1120, 1190, 'ZoomWin', CAPTION102929024, 'NONE', HIGHNONE);"><INPUT value=Zoom type=submit></FORM></TD><SCRIPT language=JavaScript> <!--var HIGHNONE = '';var CAPTION102929024 = "Steps 26-30";// --> </SCRIPT><TD><FORM method=post action="javascript:SizedForPrint('/alldata/PRO~V207882618~C42602~R0~OB0~P2R0X~N/0/89012112/94695002/94695157/119125426/34853741/34857029/34857030/34857663/122915129/105258193/159346059/164572817/102929024', 1, 650, 690, 'ZoomWin', CAPTION102929024, 'NONE', HIGHNONE);"><INPUT value="Sized for Print" type=submit></FORM></TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
<SCRIPT language=JavaScript> <!--var HIGHNONE = '';var LOWNONE = '';// --> </SCRIPT><TABLE border=0 cellSpacing=0 cellPadding=0 width="90%" align=center><TBODY><TR><TD><TABLE border=1 cellSpacing=0 cellPadding=0 width=568><TBODY><TR><TD bgColor=#ccffcc width=568 align=middle>Steps 31-35</TD></TR><TR><TD></TD></TR></TBODY></TABLE></TD></TR><SCRIPT language=JavaScript> <!--var CAPTION102929025 = "Steps 31-35";// --> </SCRIPT><TR><TD><TABLE border=0 cellSpacing=0 cellPadding=2 width=568 align=left><TBODY><TR><TD><FORM method=post action="javascript:Zoom('/alldata/PRO~V207882618~C42602~R0~OB0~P2R0H~N/0/89012112/94695002/94695157/119125426/34853741/34857029/34857030/34857663/122915129/105258193/159346059/164572817/102929025', 1, 1136, 1314, 'ZoomWin', CAPTION102929025, 'NONE', HIGHNONE);"><INPUT value=Zoom type=submit></FORM></TD><SCRIPT language=JavaScript> <!--var HIGHNONE = '';var CAPTION102929025 = "Steps 31-35";// --> </SCRIPT><TD><FORM method=post action="javascript:SizedForPrint('/alldata/PRO~V207882618~C42602~R0~OB0~P2R0X~N/0/89012112/94695002/94695157/119125426/34853741/34857029/34857030/34857663/122915129/105258193/159346059/164572817/102929025', 1, 650, 751, 'ZoomWin', CAPTION102929025, 'NONE', HIGHNONE);"><INPUT value="Sized for Print" type=submit></FORM></TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
<SCRIPT language=JavaScript> <!--var HIGHNONE = '';var LOWNONE = '';// --> </SCRIPT><TABLE border=0 cellSpacing=0 cellPadding=0 width="90%" align=center><TBODY><TR><TD><TABLE border=1 cellSpacing=0 cellPadding=0 width=560><TBODY><TR><TD bgColor=#ccffcc width=560 align=middle>Steps 36-41</TD></TR><TR><TD></TD></TR></TBODY></TABLE></TD></TR><SCRIPT language=JavaScript> <!--var CAPTION102929026 = "Steps 36-41";// --> </SCRIPT><TR><TD><TABLE border=0 cellSpacing=0 cellPadding=2 width=560 align=left><TBODY><TR><TD><FORM method=post action="javascript:Zoom('/alldata/PRO~V207882618~C42602~R0~OB0~P2R0H~N/0/89012112/94695002/94695157/119125426/34853741/34857029/34857030/34857663/122915129/105258193/159346059/164572817/102929026', 1, 1120, 1265, 'ZoomWin', CAPTION102929026, 'NONE', HIGHNONE);"><INPUT value=Zoom type=submit></FORM></TD><SCRIPT language=JavaScript> <!--var HIGHNONE = '';var CAPTION102929026 = "Steps 36-41";// --> </SCRIPT><TD><FORM method=post action="javascript:SizedForPrint('/alldata/PRO~V207882618~C42602~R0~OB0~P2R0X~N/0/89012112/94695002/94695157/119125426/34853741/34857029/34857030/34857663/122915129/105258193/159346059/164572817/102929026', 1, 650, 734, 'ZoomWin', CAPTION102929026, 'NONE', HIGHNONE);"><INPUT value="Sized for Print" type=submit></FORM></TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
<SCRIPT language=JavaScript> <!--var HIGHNONE = '';var LOWNONE = '';// --> </SCRIPT><TABLE border=0 cellSpacing=0 cellPadding=0 width="90%" align=center><TBODY><TR><TD><TABLE border=1 cellSpacing=0 cellPadding=0 width=560><TBODY><TR><TD bgColor=#ccffcc width=560 align=middle>Steps 42-46</TD></TR><TR><TD></TD></TR></TBODY></TABLE></TD></TR><SCRIPT language=JavaScript> <!--var CAPTION102929027 = "Steps 42-46";// --> </SCRIPT><TR><TD><TABLE border=0 cellSpacing=0 cellPadding=2 width=560 align=left><TBODY><TR><TD><FORM method=post action="javascript:Zoom('/alldata/PRO~V207882618~C42602~R0~OB0~P2R0H~N/0/89012112/94695002/94695157/119125426/34853741/34857029/34857030/34857663/122915129/105258193/159346059/164572817/102929027', 1, 1120, 1187, 'ZoomWin', CAPTION102929027, 'NONE', HIGHNONE);"><INPUT value=Zoom type=submit></FORM></TD><SCRIPT language=JavaScript> <!--var HIGHNONE = '';var CAPTION102929027 = "Steps 42-46";// --> </SCRIPT><TD><FORM method=post action="javascript:SizedForPrint('/alldata/PRO~V207882618~C42602~R0~OB0~P2R0X~N/0/89012112/94695002/94695157/119125426/34853741/34857029/34857030/34857663/122915129/105258193/159346059/164572817/102929027', 1, 650, 689, 'ZoomWin', CAPTION102929027, 'NONE', HIGHNONE);"><INPUT value="Sized for Print" type=submit></FORM></TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
<SCRIPT language=JavaScript> <!--var HIGHNONE = '';var LOWNONE = '';// --> </SCRIPT><TABLE border=0 cellSpacing=0 cellPadding=0 width="90%" align=center><TBODY><TR><TD><TABLE border=1 cellSpacing=0 cellPadding=0 width=576><TBODY><TR><TD bgColor=#ccffcc width=576 align=middle>Steps 47-51</TD></TR><TR><TD></TD></TR></TBODY></TABLE></TD></TR><SCRIPT language=JavaScript> <!--var CAPTION102929028 = "Steps 47-51";// --> </SCRIPT><TR><TD><TABLE border=0 cellSpacing=0 cellPadding=2 width=576 align=left><TBODY><TR><TD><FORM method=post action="javascript:Zoom('/alldata/PRO~V207882618~C42602~R0~OB0~P2R0H~N/0/89012112/94695002/94695157/119125426/34853741/34857029/34857030/34857663/122915129/105258193/159346059/164572817/102929028', 1, 1152, 1368, 'ZoomWin', CAPTION102929028, 'NONE', HIGHNONE);"><INPUT value=Zoom type=submit></FORM></TD><SCRIPT language=JavaScript> <!--var HIGHNONE = '';var CAPTION102929028 = "Steps 47-51";// --> </SCRIPT><TD><FORM method=post action="javascript:SizedForPrint('/alldata/PRO~V207882618~C42602~R0~OB0~P2R0X~N/0/89012112/94695002/94695157/119125426/34853741/34857029/34857030/34857663/122915129/105258193/159346059/164572817/102929028', 1, 650, 771, 'ZoomWin', CAPTION102929028, 'NONE', HIGHNONE);"><INPUT value="Sized for Print" type=submit></FORM></TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
<SCRIPT language=JavaScript> <!--var HIGHNONE = '';var LOWNONE = '';// --> </SCRIPT><TABLE border=0 cellSpacing=0 cellPadding=0 width="90%" align=center><TBODY><TR><TD><TABLE border=1 cellSpacing=0 cellPadding=0 width=568><TBODY><TR><TD bgColor=#ccffcc width=568 align=middle>Steps 52-59</TD></TR><TR><TD></TD></TR></TBODY></TABLE></TD></TR><SCRIPT language=JavaScript> <!--var CAPTION102929029 = "Steps 52-59";// --> </SCRIPT><TR><TD><TABLE border=0 cellSpacing=0 cellPadding=2 width=568 align=left><TBODY><TR><TD><FORM method=post action="javascript:Zoom('/alldata/PRO~V207882618~C42602~R0~OB0~P2R0H~N/0/89012112/94695002/94695157/119125426/34853741/34857029/34857030/34857663/122915129/105258193/159346059/164572817/102929029', 1, 1136, 1326, 'ZoomWin', CAPTION102929029, 'NONE', HIGHNONE);"><INPUT value=Zoom type=submit></FORM></TD><SCRIPT language=JavaScript> <!--var HIGHNONE = '';var CAPTION102929029 = "Steps 52-59";// --> </SCRIPT><TD><FORM method=post action="javascript:SizedForPrint('/alldata/PRO~V207882618~C42602~R0~OB0~P2R0X~N/0/89012112/94695002/94695157/119125426/34853741/34857029/34857030/34857663/122915129/105258193/159346059/164572817/102929029', 1, 650, 758, 'ZoomWin', CAPTION102929029, 'NONE', HIGHNONE);"><INPUT value="Sized for Print" type=submit></FORM></TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
<SCRIPT language=JavaScript> <!--var LOWmap164572818 = '<map Name = "map164572818"><area coords="394, 536, 442, 547" href="http://www.alldatapro.com/alldata/PRO~V207882618~C42602~R0~OD~N/0/89012112/94695002/94695157/119125426/34853741/34857029/34857030/34857663/122908533"></map>'var HIGHmap164572818 = '<map Name = "map164572818"><area coords="789, 1072, 886, 1094" href="http://www.alldatapro.com/alldata/PRO~V207882618~C42602~R0~OD~N/0/89012112/94695002/94695157/119125426/34853741/34857029/34857030/34857663/122908533"></map>'// --> </SCRIPT><SCRIPT language=JavaScript> <!--document.write(LOWmap164572818);// --> </SCRIPT><MAP name=map164572818><AREA href="http://www.alldatapro.com/alldata/PRO~V207882618~C42602~R0~OD~N/0/89012112/94695002/94695157/119125426/34853741/34857029/34857030/34857663/122908533" coords="394, 536, 442, 547"></MAP><TABLE border=0 cellSpacing=0 cellPadding=0 width="90%" align=center><TBODY><TR><TD><TABLE border=1 cellSpacing=0 cellPadding=0 width=568><TBODY><TR><TD bgColor=#ccffcc width=568 align=middle>Steps 60-63</TD></TR><TR><TD></TD></TR></TBODY></TABLE></TD></TR><SCRIPT language=JavaScript> <!--var CAPTION164572818 = "Steps 60-63";// --> </SCRIPT><TR><TD><TABLE border=0 cellSpacing=0 cellPadding=2 width=568 align=left><TBODY><TR><TD><FORM method=post action="javascript:Zoom('/alldata/PRO~V207882618~C42602~R0~OB0~P2R0H~N/0/89012112/94695002/94695157/119125426/34853741/34857029/34857030/34857663/122915129/105258193/159346059/164572817/164572818', 1, 1136, 1207, 'ZoomWin', CAPTION164572818, 'map164572818', HIGHmap164572818);"><INPUT value=Zoom type=submit></FORM></TD><SCRIPT language=JavaScript> <!--var HIGHNONE = '';var CAPTION164572818 = "Steps 60-63";// --> </SCRIPT><TD><FORM method=post action="javascript:SizedForPrint('/alldata/PRO~V207882618~C42602~R0~OB0~P2R0X~N/0/89012112/94695002/94695157/119125426/34853741/34857029/34857030/34857663/122915129/105258193/159346059/164572817/164572818', 1, 650, 690, 'ZoomWin', CAPTION164572818, 'NONE', HIGHNONE);"><INPUT value="Sized for Print" type=submit></FORM></TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
lynnboy021's Avatar
The numbers below refer to the step numbers on the diagnostic table.
  1. This step determines if excessive resistance is the cause for an inoperative AIR pump. Two ohms of resistance on this circuit can prevent the AIR pump from running.
  2. This step determines if the AIR system is operating normally.
  1. This step inspects for a restriction in the engine vacuum supply to the AIR shut-off valve.
  1. This step determines if the lack of air is caused by an open or a restriction in the AIR supply hose, or if an inoperative AIR shut-off valve is causing this condition. There should be a steady forceful flow of air from the AIR pump.
Old Mar 6, 2011 | 9:24 PM
EinST's Avatar
As lynnboy021 kindly posted (thanks), it's not that easy to troubleshoot. Also, most of the diagnostics in the SI can't be performed without the Tech 2. The best we can do is to make sure the AIR pump actually runs and AIR plumbing (pipes and hoses) don't have blockages or leaks. If the pump runs, we can assume that the PCM can command it through the relay and both the motor and solenoid are getting power.
Old Mar 7, 2011 | 7:14 PM
pallettman's Avatar
Thanks, lynnboy for all the help, now all I have to do is go back to school for
7 years to get my doctorate in auto diagnostics. Seriously, though, I was looking
through
your diagrams, and I was wondering about the relay. Both times the light came on, I had just gone over a large bump in the road on my daily commute. Where is this relay at. Right now, I don't have the time or money to spend that I really need to, but I am looking at this problem a little at the time. But thanks you guys for the info.
Old Mar 22, 2012 | 2:36 PM
ruth burt's Avatar
Angry 2001 chevy s10 pick up with code po410
i need assitance with this... i need a diagram so i can find what wrong with it ...... here is the code po410 please help
Mom2ThreeACG
Traverse
Mar 12, 2018 6:20 PM
mwehrste
Dec 29, 2014 11:19 AM
TexasLonghorn1971
Aug 28, 2013 7:22 PM
surfandride
Jan 16, 2011 10:05 PM
indyguy1986
Nov 14, 2007 7:15 PM
