S-10 & Blazer 1982-2005
Starting Problems
Old Sep 15, 2009 | 11:55 PM
runkart's Avatar
Default Starting Problems
1995 S-10 Blazer, when I try to start it, it sounds like the battery is weak, just barely turns over, but if you stay with it, it will eventually start. Replaced the battery, replaced starter with one from wreckin yard, same results. I'm wonderin if its not in the timin, looked in the Chiltons book and it says theres a tan wire with a black stripe that has to be disconnected before settin the timin, I've looked high and low for this wire and can't find it anywhere. Do they all have this wire? If so exactly where is it? I also have been told you can't set the timin on some models, if thats the case reckon whats wrong with my startin system?
Old Sep 16, 2009 | 1:20 AM
runkart's Avatar
Okey doke, never mind, it was my dumb butt fault all along, changed cap and rotor a while back and didn't get the rotor pushed all the way down, kinda buggered up the rotor and cap, had the old cap and rotor put them back on started just fine
Old Sep 16, 2009 | 1:28 AM
Mike Sigmond's Avatar
ROTM Coordinator
Well there you have it.
Welcome to the forum.
Mom2ThreeACG
Traverse
Mar 12, 2018 6:20 PM
mwehrste
Dec 29, 2014 11:19 AM
quackpe
Jan 31, 2006 6:24 PM
