Code retrieval and wheel ??
Just purchased a 2006 Z-71. PO told me the check engine light is on due to the 02 sensor, Is there a way to retrieve the code without a scanner. I thought there was a way on pre 99 but did not know if it was possible.
Also - will stock Chevy 16" wheels from an '03 fit / clear the rotors/brakes without issue or do i need to stick with the 17".
thanks for the replies.
thanks kevinpk, thanks for the correction of years,
i realize that the auto parts will read it for me. that was not the question. is your answer no the code can not be read without a scanner?
thanks
thanks
May be true, but in 05-07 silverados came with 13" rotors up front and drums out back. With these rotors you could only run a 17 or bigger. 16s will work with some grindin on the caliper
Vinna
Express & G-Series Vans
November 12th, 2012 8:51 AM
rap1
October 26th, 2008 12:44 AM
