Notices
Sponsored by: DashLynx
oil pan removal
Old December 12th, 2010, 10:16 PM
walterj223's Avatar
Default oil pan removal
I am having trouble removing the oil pan on a 98 w/t 2wd 4.3L. All bolts that i can see are removed butthe pan will not come off. Any suggestion? Am I missing something?
Old December 12th, 2010, 11:03 PM
BayAreaChevyGuy's Avatar
Its probably baked on there, ya know? Try to use a flat head screw driver to help it along.
Also, I bet theres a vaccume sort of pressure holding it in as well. Try taking the oil fill cap off.
Old December 20th, 2010, 9:19 PM
usmarine0905's Avatar
Becareful if you use a flat tip screw driver... try not to nick the pan or block or you could have a leak in the future. I would use a block of wood and good mallet on the corners of the pan and swing away..... good luck. don't know if you will have to raise the engine to clear the girdill......
Old December 20th, 2010, 9:34 PM
Mille Racer 69's Avatar
Pretty much what I was gonna say, the pan is probably cooked to the gasket and the
Gasket to the main body.
Try using a rubber mallet. You can get 1 for like 1.50 in the outdoors section at WalMart.
Then try knocking downwards on it, and carefully see if you might be able to wedge something
In between the pan and the body and carefully pry it out.
Or firmly grasp each side of the pan and jerk it side to side while pulling down.
Also, I strongly suggest you have the truck on ramps while doing this.
Not jackstands or jacks, ramps that you drive up onto.
Oh, and you had better replace that oil pan gasket with a new 1 before you
Put the pan back on or I would be willing to bet you that you will start to see
Drops of oil in your driveway in the near future.
Old March 20th, 2020, 3:52 AM
Kayla Bauer's Avatar
Default Need to replace my oil pan on 99 chevy tahoe 4x4
The last oil change we did my dad tightened it too much now i realized my tread is stripped and cant change my oil costing me to replace the oil pan.
i have the gasket and new pan. I never replaced the oil pan in my life before. I was wondering if anyone can tell me step by step what to do? I cant find steps anywhere. I need to do it asap! Please help
Old March 20th, 2020, 8:57 AM
99 new body style or 9 old bodystyle? What engine?
Old March 20th, 2020, 1:48 PM
In case you're not aware, there are kits for repairing oil pan threads. Installs in 10 minutes and they seal perfectly.
Rednucleus (March 20th, 2020)
Old March 20th, 2020, 2:11 PM
v8 5.7l
Old body
Old March 20th, 2020, 7:15 PM
I didnt know honestly. Ill look it up. But we do have the pan already.
Old March 20th, 2020, 9:54 PM
thread repair kit is much easier. If the pan is not severely rusted i'd go that way. pan removal is probably a 4 hr job. you have to lower the front diff, lift the engine up to get clearance to slide the pan out.
gebudjr
October 26th, 2010 3:46 PM
tudorstyle
September 17th, 2010 12:26 PM
ukrkoz
February 15th, 2010 7:49 PM
mattwehrwein
February 2nd, 2010 1:29 PM
xzspk5
Express & G-Series Vans
July 4th, 2009 6:59 AM
Quick Reply: oil pan removal
