2007 Chevrolet cruise control not working
Old Nov 7, 2011 | 11:43 PM
blakeconway's Avatar
Default 2007 Chevrolet cruise control not working
I have a 2007 SilveradoLTZ, 4WD, 5.3L. Over the past few months my cruise control has worked and not worked for no apparent reason. Some days I would get in it to go to work and the cruise would work normally and if I had to hit the brakes for any reason it may or may not come back on at all. Now we're to the point where it doesn't work at all anymore. The on/off switch still lights up and I have checked all the fuses. Checked brake pedal and switch. I have no idea where else to begin.
Any help would be greatly appreciated.
Old Nov 8, 2011 | 5:48 PM
EinST's Avatar
Welcome to the forum. The stop lamp switch actually has two different circuits. The next time it the cruise control fails to engage, try pulling up on the brake pedal with your foot. If that makes it work, you'll want to take a second look at the stop lamp switch.
Old Jul 12, 2021 | 12:24 PM
JohnR1002's Avatar
Angry 07 Cruise and stop lights not working
I have a 07 2500HD Classic, the cruise control and brake lights (on the tail lights) not working. Changed the brake light switch and this was not the problem. I have brake lights on the cab light and trailer brake lights. It keeps blowing the Vehicle Stop 15amp fuse. I can change the fuse while the truck is running and the cruise will work, as soon as i turn the engine off the fuse is blown and brake lights ( on the tail lights) and cruise no longer work. Any ideas will be greatly appreciated.
Old Jul 12, 2021 | 6:13 PM
kevinkpk's Avatar
Possible turn signal switch
Old Jul 12, 2021 | 10:32 PM
oilcanhenry's Avatar
Might try squirting a very tiny amount of contact cleaner in the switch, but cover your painted indicators with tape of some kind, as it might harm them if the contact cleaner gets on them. Keep toggling the switch while you apply the C-C. Let it dry out, it won't take long.
Dan Metiva III
Oct 26, 2020 4:00 PM
dfw
Dec 6, 2014 5:39 AM
chevyridinghi
Jun 4, 2009 8:07 PM
AviD
Jun 26, 2007 10:41 AM
amos221
Jan 10, 2007 11:42 AM
