2007 Chevy 1500 front end popping when turning sharp
Old Mar 22, 2015 | 11:56 AM
07Chevyboy's Avatar
Default 2007 Chevy 1500 front end popping when turning sharp
I have a popping noise in my front end (passenger side I believe) when I turn sharp... Any ideas...? Looked at my tie rods and the outer (both sides) have the boots cracked... Was thinking its those but how can I check to see if they are bad...? Also I noticed a piece that looks bad on both sides but no clue what it is...
Attached Thumbnails 2007 Chevy 1500 front end popping when turning sharp-image.jpg
Old Mar 22, 2015 | 11:58 AM
07Chevyboy's Avatar
Another pic
Old Mar 22, 2015 | 11:59 AM
07Chevyboy's Avatar
Tie rod boot
Old Mar 22, 2015 | 12:01 PM
07Chevyboy's Avatar
Other boot
Old Mar 22, 2015 | 6:38 PM
poncho62's Avatar
Have someone wiggle the steering back and forth while you watch those joints and see if you can see any movement.
Those joints at the end of the rack and pinion seem like they dont line up too well.
Those cracked rubbers on the stabilizer bar would cause more of a rattle when you hit a bump rather than a popping when you turn. They could use replacing anyways, but dont think thats your problem
Old Mar 30, 2015 | 9:31 PM
07Chevyboy's Avatar
I put some new tires on, replaced the tie rods and sway bar link on both sides and seems to be good now...Then took up to get an alignment done...
jensenracing77@yahoo.com
May 11, 2011 5:41 PM
cox222
Jul 19, 2010 12:47 AM
unboundtrucker
Dec 16, 2009 7:24 AM
tonzmn
May 15, 2009 12:06 PM
DomRulz96021
K5 Blazer
Aug 10, 2007 6:17 PM
