2007 NBS Transmisson Smell ?
Old Oct 1, 2007 | 9:35 PM
Rod Man's Avatar
Default 2007 NBS Transmisson Smell ?
Hey Guys, I just bought a new 2007 NBS Silverado with the 4.8 engine, 342 rearend it's the W/T edition with the LS package. well my question is it has 300 miles on it now and i smell something like hot transmission fluid after driving and getting it hot. i pulled a 14ft. box trailer empty about 15 miles tonight and when i get home you could smell that trans fluid even my wife smelled it. the computer said trans temp was 196 degrees is this normal for a new truck? is it just burning off the new ? and what's normal operating temp for the transmission ?
Thanks, Rodney
Old Oct 2, 2007 | 10:39 AM
ax7221's Avatar
Default RE: 2007 NBS Transmisson Smell ?
I've got a 5.3 371 w/t with the LS havent towed anything, and have yet to smell anything
Old Oct 2, 2007 | 11:07 AM
chicken_buster's Avatar
I have almost the same truck with 5000kmsand have not smelled any tranny fluid at all.
Old Oct 2, 2007 | 7:31 PM
IAfarmer's Avatar
I would get it in the shop ASAP. The only thing I smelled when my truck was new was the coating of shipping oil burning off the exhaust.
Old Oct 3, 2007 | 10:21 AM
MalibuMaxxSS's Avatar
how heavy was the trailor, the 4.8 and 3.42 is NOT a good combo to be pulling with...
Old Oct 3, 2007 | 3:08 PM
ZX1100F1's Avatar
Your new 2007 Silverado is designed to tow up o 5,900lbs.
196 degrees F is not in the danger zone yet, but you want to keep the tranny as cool as possible.
I would recommend having a tranny cooler (GM part #19171483) installed if you plan on using it to tow regularly
The hot burning odor is probably just the Cosmoline preservative (that is applied to the undercarriage prior to leaving the factory) burning off the exhaust system and nothing to worry about, it should go away soon.
Old Oct 3, 2007 | 4:38 PM
Rod Man's Avatar
ORIGINAL: MalibuMaxxSS
I have no idea, sorry ! but it's a 14ft boxed with sheet metal , Leanord Truck Accessery sells them.
Old Oct 3, 2007 | 4:43 PM
Rod Man's Avatar
also i ordered the tranny cooler today. is it hard to install ? i'm not to good with mechanic work [sm=grin.gif]
Old Oct 3, 2007 | 4:47 PM
they are not that hard, but have the GM guys do it so you get the warranty, all you need is a tranny failure and they say 'well you did hte install on the cooler so your fault'..........last one I did was like 190 bucks not much...
hogs29
Nov 2, 2010 9:17 PM
sekeraksm
Oct 27, 2010 10:05 AM
dvx1120
Aug 14, 2010 1:09 AM
NXVETTE
Sep 7, 2009 9:21 PM
elcaminomike
Chevelle & El Camino
Mar 11, 2006 10:12 PM
