2008 silverado brake lights stay on
Old Apr 20, 2015 | 7:29 PM
andrewpowell's Avatar
Default 2008 silverado brake lights stay on
have a 2008 silverado and a few days ago the brake lights stay on when the truck is on. have replaced brake switch, checked wiring harness junction box, unplugged wiring from brake light switch, and brown plug from bcm module, they went out when i pulled fuse, and when i unplugged from bcm module. any ideas? thanks much
Old Apr 20, 2015 | 11:13 PM
jamespsj's Avatar
I saw a similar issue here https://answers.yahoo.com/question/i...4062906AAYxkiP The owner's brake lights are stuck on as well. In his case the dealer traced it to a faulty junction box. They replaced it and it solved the issue.
Old Apr 21, 2015 | 5:14 AM
Default Thank you
Switched junction box out with another one. Still having same issue.
Old Feb 26, 2020 | 3:00 PM
2 Ol' Vets's Avatar
Default And the issue was?
just had booster go out. Replaced and now have the light issue. Changed switch on pedal, and tested unplugged, stays on. Haven’t tried the brain yet, did you figure out your issue and what was it?
Old May 27, 2022 | 1:55 AM
09Tahoe_SSV's Avatar
I have the same issue with my 09 Tahoe. I replaced the Brake switch on the pedal. That didn't work
Old May 27, 2022 | 3:29 AM
HHR guru's Avatar
replace the brake light switch on the back of the brake pedal
Afitz09
May 27, 2022 3:32 AM
sorensen3724
Sep 19, 2015 5:54 PM
Malissav75
Mar 28, 2015 6:27 PM
chevman711
Sep 20, 2010 1:41 PM
mike79K5
K5 Blazer
Jun 5, 2009 12:25 PM
