cruise not working
cruise not working
Hi im new looking for some info. i have a 2004 silverado 2500 and the cruise control has gone out. I have already checked the fuses by the door and that was good. If anyone has any ideas i could use the help. Thanks
RE: cruise not working
Possible failure pointsinclude the multi-function switch (turn signal lever with all the switches), thePowertrain Control Module,and theCruise Control Module, or it could be aconnector in the wiring harness. You will probably need to have someone do a diagnostic check on the cruise control system topinpoint what's not working right rather than to just start throwing parts at it trying to accidently hit theproblem.
This one might sound a little funny but I have a 93 Caprice and when the center brake light burns out my cruise control stops working.
Let me know if this works!
i would check the wireing !!! but between fueses and wires you should find your problem i am having a similar problem with my radio,gueges and auto lights lol good luck and take your time
ORIGINAL: kenneth1976
how do you check the brake pedal switch to see if its good with out just replacing it.
mossyoak
16
April 12th, 2023 8:40 AM
KC-RUNNER
December 18th, 2009 8:36 PM
chevyridinghi
June 4th, 2009 8:07 PM
